Gap between flares and body https://www.ausmini.com/forums/viewtopic.php?f=2&t=45601 |
Author: | EAB [ Tue Sep 09, 2008 10:48 am ] |
Post subject: | Gap between flares and body |
hello all i have just fitted the sportspack flares to my mini. think i did an ok job but i have one question. where there is a larger gap than the black strip that comes with them betweent the flare and the body what can i do to fill that gap? also where the flares end, eg front lip and back edge of the flare (where they curl under the bumpers), should i fix that edge in place or leave it? how would i go about this. figured i could silicone it, etch prime and paint? will load some pics tonight to make it clearer |
Author: | Harley [ Tue Sep 09, 2008 11:15 am ] |
Silicon and paint don't mix. One will eat the other. Look for a wider rubber strip, it'll look neater. ![]() |
Author: | Mick [ Tue Sep 09, 2008 12:29 pm ] |
Harley wrote: Silicon and paint don't mix. One will eat the other.
Look for a wider rubber strip, it'll look neater. ![]() Not always true, there are silicones which are acidic and ones which are not (waterbased). Look for the right product and you might get the result you are after. |
Author: | peterw [ Tue Sep 09, 2008 12:33 pm ] |
I would be looking for a wider rubber strip. If you find a silicone that is paintable then over time the paint will most likely crack as the panel flexes in use. Pete |
Author: | mini-dunger [ Tue Sep 09, 2008 6:37 pm ] |
go down to clark rubber, they sell this rubber strip stuff thats shaped like a P. It sits in place well and would definatly fill any gaps |
Author: | drmini in aust [ Tue Sep 09, 2008 8:25 pm ] |
peterw wrote: I would be looking for a wider rubber strip. If you find a silicone that is paintable then over time the paint will most likely crack as the panel flexes in use.
Pete Use Sikaflex, it cures to a polyurethane rubber and is paintable. I like grade 291, I get it from Bias Boating warehouse. Comes in black, or white... |
