It is currently Tue Jul 29, 2025 1:08 am
PostPosted: Tue Sep 09, 2008 10:48 am
hello all i have just fitted the sportspack flares to my mini. think i did an ok job but i have one question.
where there is a larger gap than the black strip that comes with them betweent the flare and the body what can i do to fill that gap?
also where the flares end, eg front lip and back edge of the flare (where they curl under the bumpers), should i fix that edge in place or leave it? how would i go about this.
figured i could silicone it, etch prime and paint?
will load some pics tonight to make it clearer
1962 850,Frog
PostPosted: Tue Sep 09, 2008 11:15 am
Silicon and paint don't mix. One will eat the other.
Look for a wider rubber strip, it'll look neater.
:D
PostPosted: Tue Sep 09, 2008 12:29 pm
:D
Not always true, there are silicones which are acidic and ones which are not (waterbased). Look for the right product and you might get the result you are after.
PostPosted: Tue Sep 09, 2008 12:33 pm
I would be looking for a wider rubber strip. If you find a silicone that is paintable then over time the paint will most likely crack as the panel flexes in use.
Pete
PostPosted: Tue Sep 09, 2008 6:37 pm
go down to clark rubber, they sell this rubber strip stuff thats shaped like a P. It sits in place well and would definatly fill any gaps
blokeinamoke wrote:
PostPosted: Tue Sep 09, 2008 8:25 pm
Pete
Use Sikaflex, it cures to a polyurethane rubber and is paintable.
I like grade 291, I get it from Bias Boating warehouse. Comes in black, or white...
