It is currently Sat Jul 19, 2025 1:45 pm
PostPosted: Fri Feb 04, 2005 6:04 pm
A while back when I raided the local wreckers for Civic dics I got everything but one of the discs wouldn't budge and I ran out of time as they were closing - I happened to be passing before Christmas and went in and sized up what I thought I'd need to get it off.
Today I went back with the BFH and the impact driver and not a bloody Civic in sight - All gone - zilch - not one Gone to the crusher says the man in charge :cry:
David L
PostPosted: Fri Feb 04, 2005 6:22 pm
What wreckers was that Wombat????? :?
I got nuthin......................
PostPosted: Fri Feb 04, 2005 11:01 pm
maybe a stupid quesiton
but why not just get new disks?
if you pull them off with a BFH then you are likely to mark the rotors and render them fairly useless
if you are gonna bash them off atleast use some care and use a rubber mallet
sorry just a question that always confuses me
PostPosted: Sat Feb 05, 2005 6:35 am
DBA191 is the # of the disc, I think they're only $50 or so new. 8)
PostPosted: Sat Feb 05, 2005 7:51 am
I did think that it would be better to get new ones undrilled and have the studs drilled to the right spacing :roll:
David L
PostPosted: Sat Feb 05, 2005 7:55 am
SG It was the ABC Wreckers at Oxley - there is a Pulsar with a D85 dizzy in it - I removed it from the block but when I pulled the coil lead off the cap was broken. Decided I didn't really need it so left it with LT leads attached behind the grill
David L
PostPosted: Sat Feb 05, 2005 8:00 am
He said a BFH AND an Impact Driver, which will get them off no problems, if they were there. you don't actually bash the disk off...
I agree, just go buy a pair new..
PostPosted: Sat Feb 05, 2005 6:50 pm
hey!! go back and grab it for me could you - I'll buy a new cap at repco!
PostPosted: Sat Feb 05, 2005 7:26 pm
Unfortunately I'm tied to the house until next Saturday. I'm on-call for work all weekend 24 hours a day Sat and Sun and 7:30 pm to 7 am weeknights Sorry - :cry:
David L
Users browsing this forum: Bing [Bot] and 78 guests
