It is currently Sun Aug 03, 2025 6:51 am
PostPosted: Mon Sep 15, 2008 7:23 pm
The thread on my crankshaft at the pulley end is damaged, does anyone have a 5/8 x 16 tap we could beg,borrow or buy ? i live in the Sutherland shire Sydney and don't think i could live without Charlie for more than a few days :cry: i don't mind traveling a bit to pick it up.
Thanks
Boo the Hamster
PostPosted: Mon Sep 15, 2008 7:51 pm
High heel ninja
Graham Russell could fix it, or Tony at Mimi Spares at Padstow 9774 3366
Doogie
PostPosted: Mon Sep 15, 2008 9:04 pm
Thanks for that, problem is i cant really see how i'm going to get the engine to mini spares, don't really want to take it out again. found a tap in England and can get it for about $30. might do that
PostPosted: Mon Sep 15, 2008 10:55 pm
isnt that the thread that is really odd and you cant match it because it is really weird (ie not common - generally no god once wrecked)??
Brenton
PostPosted: Tue Sep 16, 2008 6:49 am
Brenton
The thread in both ends of the crank is 5/8-16TPI. Supposedly it's a UNS thread (neither UNF or UNC).
I had a crank in storage once and wasps made a mud nest in it. I got an old flywheel bolt and ground 4 grooves along it, it worked OK to chase the muck out of the threads.
May not work if threads are physically damaged.
Another method is to get a machine shop to set the crank up in a lathe and chase the threads with a screwcutting tool. :wink:
