whats the difference https://www.ausmini.com/forums/viewtopic.php?f=2&t=45820 |
Page 1 of 2 |
Author: | i got a mini [ Tue Sep 16, 2008 8:25 am ] |
Post subject: | whats the difference |
hey guys i was at a mate house the other day and they own a austin healey sprit and i wanted to no is there any difference in the motors between that and a 1100cc ????????? |
Author: | Blokeinamoke [ Tue Sep 16, 2008 8:30 am ] |
location location location. The way the engine faces, the way the gearbox and diff are located, the sump and other gubbins. |
Author: | i got a mini [ Tue Sep 16, 2008 8:31 am ] |
no like is there any difference bewteen the blocks cause like i no theres is rear wheel drive and there gear box ect different but is there any difference between the blocks |
Author: | Anto [ Tue Sep 16, 2008 8:33 am ] |
Yes the blocks are different - rear main cap is different. Yes with a bit of work you could convert it but why would you? 998/1100 Mini blocks aren't that scarce. |
Author: | i got a mini [ Tue Sep 16, 2008 8:34 am ] |
oh casue my mates needs a 1100 hundred crank casue is crank is shot and i was just seeing if a standard mini 1100 crank would fit into the motor would that work |
Author: | Anto [ Tue Sep 16, 2008 8:53 am ] |
No they are not interchangeable. |
Author: | sports850 [ Tue Sep 16, 2008 9:33 am ] |
Anto wrote: No they are not interchangeable.
As Anto has said , the flywheel ends of the crank are very different , the mini one has the long nose to take the mini specific clutch setup (clutch between the flywheel and motor) whereas the Sprite was more on the conventional lines (clutch behind the flywheel and motor) . From memory there was a UK Marina with the 1100 and 1275 longitudinal motors so might be worth trying contacts in the UK . Not sure about Morris Minors either but I think they only had a 998 and not an 1100 (someone else can answer that one ) . |
Author: | Anto [ Tue Sep 16, 2008 9:46 am ] |
Late model Morris Minors did have 1100s from about 1962, however in Aus the Minor had been discontinued by then. You will find the odd imported model though. Doesn't really make it any easier to find an 1100 RWD crank though! |
Author: | Mick [ Tue Sep 16, 2008 12:47 pm ] |
A Morris Minor fellow I knew spent a few hundred dollars getting a 1275 crank converted to inline by welding a drive flange in place of the tail. I don't know how desperate Sprites are for cranks however, and if it would be worth it... |
Author: | 1310/71 [ Tue Sep 16, 2008 12:54 pm ] |
I would suggest he talk to Colin Dodds at Spriteparts. Colin was located around the back of Kellyville somewhere. I know he moved, not sure how far out. He did have a website last time I looked. KB |
Author: | simon k [ Tue Sep 16, 2008 2:04 pm ] |
Mick wrote: A Morris Minor fellow I knew spent a few hundred dollars getting a 1275 crank converted to inline by welding a drive flange in place of the tail.
I don't know how desperate Sprites are for cranks however, and if it would be worth it... my dad has a 1275 in one of his minors with the crank chopped and a boss fitted (can't remember how it's fitted - it's ex-RX7, and not welded)... his mate did it for him about 15 years ago |
Author: | Mick [ Tue Sep 16, 2008 2:49 pm ] |
simon k wrote: my dad has a 1275 in one of his minors with the crank chopped and a boss fitted (can't remember how it's fitted - it's ex-RX7, and not welded)... his mate did it for him about 15 years ago Wasn't a mate up in Brisbane was it?? |
Author: | simon k [ Tue Sep 16, 2008 3:08 pm ] |
Mick wrote: simon k wrote: my dad has a 1275 in one of his minors with the crank chopped and a boss fitted (can't remember how it's fitted - it's ex-RX7, and not welded)... his mate did it for him about 15 years ago Wasn't a mate up in Brisbane was it?? nope - Shelford (- 1/2 way between Ballarat & Geelong) |
Author: | frednutz&co [ Tue Sep 16, 2008 7:17 pm ] |
if he doesn't get it working can i have the fuel tank i have been told it will fit into the rear subframe of a mini with a little bit of work ![]() only joking ![]() |
Author: | drmini in aust [ Tue Sep 16, 2008 7:33 pm ] |
Anto wrote: Late model Morris Minors did have 1100s from about 1962, however in Aus the Minor had been discontinued by then. You will find the odd imported model though. Doesn't really make it any easier to find an 1100 RWD crank though!
Note there are 2 different RWD 1098 cranks, Sprite Mk2 had 1.75" main bearings, the Mk2A had 2.0". ![]() |
