Mini height trolley jack
https://www.ausmini.com/forums/viewtopic.php?f=2&t=45821
Page 1 of 3
Author:  Lillee [ Tue Sep 16, 2008 8:46 am ]
Post subject:  Mini height trolley jack
Hello people,
Are you like me and work on your mini often? are you sick of having to use 2 jacks to get your low riding mini off the ground? well have I got a scoop for you!
Repco currently stock a trolley jack that is at it's lowest height only 14cm off the ground. It is $99 save $70.
See you this weekend at Repco! :lol:
Author:  belgord [ Tue Sep 16, 2008 8:52 am ]
not too bad at all. I usally just drive it up on a series of bricks that keep getting bigger and bigger. My own personal brick ramp :lol: . Just wish my mate would give me back my car ramps.
Brendan
Author:  ollie [ Tue Sep 16, 2008 8:58 am ]
I just have 2 short lengths of timber, drive on to those then slide the jack under
Author:  sports850 [ Tue Sep 16, 2008 9:36 am ]
I bought a $20 trolley jack from big W that fits under them easily , only lifts to about a foot high so useless on anything other than a mini but well worth the price (or it was till it blew a seal :evil: )
Author:  Lillee [ Tue Sep 16, 2008 9:44 am ]
I too have the $20 Big W trolley jack but it just doesn't fit under Lillee's sagging front hydro bags.
So i guess this problem is mine and mine alone :oops:
Author:  sports850 [ Tue Sep 16, 2008 9:46 am ]
Just how low is Lillee then ??? I've fit this one under many low mini's (hydro and lowered dry) without drama's , maybe they've changed their range , I'll go measure the lowered height of it later .
Author:  Anto [ Tue Sep 16, 2008 9:51 am ]
I always just lift the car up a bit by hand to slide the jack underneath. It's one of the wonders of hydrolastic suspension. :P
Author:  Lillee [ Tue Sep 16, 2008 10:52 am ]
Yes that's what I do too, but see with this jack, you won't need to! :P
Umm... the jack point is JUST lower than the lowest hieght on my Kmart/BigW trolley jack
Author:  sgc [ Tue Sep 16, 2008 10:58 am ]
I have a Supercrap trolley jack which fits nicely underneath the tie-rod mounts on the front of the front subframe.
Author:  Lillee [ Tue Sep 16, 2008 11:58 am ]
:shock: You shouldn't jack from that point. I have bent tie rod arm mounts on Lillee for that reason... Made proper alignment quite difficult on Lillee without the use of adjustables...
Author:  simon k [ Tue Sep 16, 2008 12:04 pm ]
so line up your jack properly, if the jack bends the ears the tie rods attach to, don't bloody drive the car cos they'll tear off one day..... my Mini K actually had the ears brazed up, I tested the brakes on day and one of them sheared - lucky I was doing a controlled test!
I've got a big arse 2 ton jack, fits everywhere under my cooper - the bigger jacks fit the lifting bit between the wheels, whereas the little ones have it above the wheels, hence sit high
Author:  doogie [ Tue Sep 16, 2008 12:05 pm ]
I have one of those $99 MVP repco jacks, its great, straight under the minis sump no worries, bargain price too, word of warning, they sell real quick, get in early.
Doogie
Author:  Blokeinamoke [ Tue Sep 16, 2008 12:14 pm ]
I have a LeeQwanFuck brand from Stupidcheap that fits perfectly
Author:  Caponix [ Tue Sep 16, 2008 12:34 pm ]
same here just recently got a trolley jack from supercrap for about $30
min lift height of about 13cm, which isnt too helpfull when your sump is about 8-10cm at the lowest point :roll: hence, 2 blocks of wood help me bump it up a few cm :lol:
i really need to get hi-lows for jester :roll: :lol: speedbumps are just painful :twisted:
Author:  Hanra [ Tue Sep 16, 2008 1:03 pm ]
I got this Omega jack through Rapeco. I think it was about $370ish. Its lowest point is 90mm
Page 1 of 3 All times are UTC + 10 hours
