Got the Rover bit... now what? (with pics...)
https://www.ausmini.com/forums/viewtopic.php?f=2&t=45865
Author:  mattsmadmini [ Wed Sep 17, 2008 1:52 pm ]
Post subject:  Got the Rover bit... now what? (with pics...)
Is a rover alternator just a plug and play type of mod? if so how is it wired up?
which wire goes where?
Author:  VicMini13 [ Thu Sep 18, 2008 8:14 am ]
Depends on how the car is wired.
If the original alternator had an internal regulator then the Rover one should just plug in. (later Clubmans)
But if the car is wired with an separate alternator then you will need some re-wiring. (Mini K's and early Clubmans)
Unfortunately by the look of the bunch of wires in your hand you have the second type and will need some wiring work.
Author:  Wombat [ Thu Sep 18, 2008 9:39 am ]
Hmmmm............ The Doc replied to this last night - now the post is missing like a few others
Author:  mattsmadmini [ Thu Sep 18, 2008 10:02 am ]
yeh.... i replied to Kev, i know that he said, the brown yellow wire goes to the little lug, then the big brown and other black (from coil) goes to the other 2 lugs.... anyone help???
Author:  jess [ Thu Sep 18, 2008 10:47 am ]
Wow Matt, you have longer fingernails than i do!
Author:  mattsmadmini [ Fri Sep 19, 2008 10:10 am ]
i still dont get it :cry:
