Valve stem seals
https://www.ausmini.com/forums/viewtopic.php?f=2&t=45876
Author:  AWOODY [ Wed Sep 17, 2008 5:13 pm ]
Post subject:  Valve stem seals
Has anyone had trouble with their vavle stem seals binding on the inner valve spring ?
Author:  simon k [ Wed Sep 17, 2008 5:29 pm ]
no, never had that problem - any details on your setup? fancy springs, caps, seating washers?
Author:  John Smidt [ Wed Sep 17, 2008 5:40 pm ]
Does Your Cylinder Head Have Inner Valve sppring locators , At the bottom around the vale guide area
Author:  aaron [ Wed Sep 17, 2008 5:42 pm ]
Kline the head, you won;t need stem seals anymore :wink:
Author:  AWOODY [ Wed Sep 17, 2008 5:45 pm ]
No fancy setup just a 1100 S head and double valve spring set part no. vsp3964p and John I am not sure about the spring locators ... interesting
Author:  John Smidt [ Wed Sep 17, 2008 5:50 pm ]
I think you have one of our cataloges, If you do have a look on page 20 item 65 that is what it looks like some cylinder heads have this machined into the head Part Number AEA403
Author:  AWOODY [ Wed Sep 17, 2008 5:59 pm ]
unfortunately I am yet to get a catalouge , I have a retail price guide from 13/10/91 however I did find it elsewere and I don't remember them being there when the valves were removed the other day, I will talk to the fixer . Thank You , it appears that the seal has been moving with the valve and pumping oil down the guide ? both inlet chambers were soaked in oil .
Author:  Anto [ Thu Sep 18, 2008 8:45 am ]
That sounds to me classic symptoms of fitting a Cooper S type valve stem seal to a guide that does not have the locating groove. The end result is the valve stem seal turns into an oil pump.
Your valve guides need to be this type in order to hold the stem seal properly:
Author:  AWOODY [ Thu Sep 18, 2008 4:23 pm ]
Thanks guys all this info is gladly recieved and passed on .
