Morris 1100 rotors https://www.ausmini.com/forums/viewtopic.php?f=2&t=45908 |
Author: | 64cooper [ Thu Sep 18, 2008 7:42 pm ] |
Post subject: | Morris 1100 rotors |
As subject says, where or who would be able to supply new rotors? |
Author: | Gordo [ Thu Sep 18, 2008 8:55 pm ] |
Are they different to mini ones? I now know the hubs and steering arms are differant ![]() |
Author: | Beanie [ Thu Sep 18, 2008 8:56 pm ] |
aren't the rotors the same as normal 8.4" mini rotors ... i know the drive flanges and uprights and calipers are different but as far as i know they are the same as mini rotors |
Author: | Convertible Mini [ Fri Sep 19, 2008 7:44 pm ] |
Post subject: | 1100 Rotors |
Yes they are different as the stud pattern is different on the Morris 1100 for a start |
Author: | madmorrie [ Fri Sep 19, 2008 8:28 pm ] |
Last time I was looking for some I was told that you can get the Mini 8.4 inch ones and have them machined down (yes, I know it's sounds odd) to the 1100 size, 8.0 I think but check the old ones for exact diameter, not sure if width is OK or not. I never had it done, but I understand this is the way to go as you would be extremely lucky to get new ones. Mini disks will bolt up in place of the 1100 ones, it's the drive flange that has the different PCD. Madmorrie |
Author: | rehab1964 [ Fri Sep 19, 2008 10:00 pm ] |
new ones turn up on ebay semi reguarly - last saw a pair maybe 3 months ago |
Author: | TheMiniMan [ Sat Sep 20, 2008 12:16 am ] |
Morris 1100 disc rotors are 8.3" diam, are slightly different, but the bolt pattern for the drive flange is the same as 8.4" rotors some people have mistakenly used them in place of mini 8.4" mini ones & have found that they need to occasionally chip off the excess brake pad material that overhangs the rotor & obviously isn`t used by the smaller diam rotor over a period of time it bunches up & plays with your head ![]() |
