sc12 parts https://www.ausmini.com/forums/viewtopic.php?f=2&t=45915 |
Author: | the vanman [ Thu Sep 18, 2008 9:53 pm ] |
Post subject: | sc12 parts |
hi all i picked i up a sc12 or sc14 at a swapmeet the other day but it is missing the pully setup, so i need the whole lot the middle bit that goes onto the shaft and a pully to run around 6psi. are there any markings on the sc14 and can anyone tell me if the pullys are the same on both? thanks gary |
Author: | gafmo [ Thu Sep 18, 2008 10:04 pm ] |
Post subject: | Re: sc12 parts |
the vanman wrote: are there any markings on the sc14
gary Hi ya Gary the Sc14 has a Dip stik which is yellow top right |
Author: | the vanman [ Tue Sep 23, 2008 9:32 am ] |
thanks i have a sc12 then. |
Author: | slinkey inc [ Tue Sep 23, 2008 12:44 pm ] |
SC12 should be clearly embossed on the body on the supercharger. |
Author: | 69elf [ Tue Sep 23, 2008 7:53 pm ] |
My SC12 has a yellow dipstick so you can't use that to distinguish between SC12 and SC14. It does have SC12 cast on to the body. I was told the other day that the SC12 has a restrictor in it which if you remove will give about 16psi instead of the standard 7psi. |
Author: | gafmo [ Tue Sep 23, 2008 8:30 pm ] |
Yep I was wrong ![]() Here's a handy link for you all 1/2 way down the Page http://www.autospeed.com/A_110294/cms/article.html |
Author: | the vanman [ Mon Oct 13, 2008 8:43 pm ] |
mine has a alloy dipstick the same as the charger. |
Author: | the vanman [ Mon Oct 13, 2008 8:45 pm ] |
but there is nothing on it at all that says what it is. |
Author: | gafmo [ Mon Oct 13, 2008 9:00 pm ] |
Note the differances between the brackets SC12 ![]() sc14 ![]() |
Author: | the vanman [ Mon Oct 20, 2008 11:37 pm ] |
that helps, thanks i have a sc14. |
