It is currently Sun Jul 27, 2025 2:31 pm
 Post subject: what makes an a-series
PostPosted: Thu Sep 18, 2008 7:39 pm
what makes an a-series motor an a-series??
Like what separates it from a b-series, apart from size?
Im just curious as i dont understand because sprite engines etc are a-series so i figured its not to do with gearbox being directly underneath.
so what differnentiates it from other motors in general?
Brenton
PostPosted: Thu Sep 18, 2008 7:42 pm
A series started with the Austin A30 and Series 2 Morris Minor, in the early 50s. That one was 803cc so the A series has come a long way.
Morris 850 was the first transverse application, but the 850 block itself is pretty much identical to a Morris Minor 1000 one, but stroke is shorter and the end of the crank is different design.
BMC used a letter code for their different block types, A, B, C, E, O are some.
PostPosted: Thu Sep 18, 2008 8:04 pm
so a-series refers the type of block manufactured by BMC?
even though same as B, C, E, O they were only differentiated by size, but all the same pretty much.
PostPosted: Thu Sep 18, 2008 8:49 pm
No , the A and B series were similar in appearance though the B series was a lot larger in every dimension (imagine a bread and butter plate beside a dinner plate , they look similar but a lot different in size) . The other motors listed were all different in other ways , some were 6 cylinder , some were overhead cam etc . The A and B being similar was just a fluke really as they were the two most common motors when they started the A , B etc engine names , the rest just followed on since they'd started the naming system .
PostPosted: Thu Sep 18, 2008 9:47 pm
oh ok i got it now
thanks Doc and sports
:D
PostPosted: Fri Sep 19, 2008 2:24 pm
When did the A+ engine appear and in what vehicles? What makes it different to an A Series engine?
PostPosted: Fri Sep 19, 2008 6:20 pm
Location: in the shed cutting, grinding and painting my shit
stronger block, more webbing
different distributor drive and distributor.
takes the "deep" (like 1275) water pump
thats all i can think of
Matt68 wrote:
I'd like to believe in Karma, however, sometimes I firmly believe we should become the instruments of Karma.
PostPosted: Fri Sep 19, 2008 6:22 pm
echo
PostPosted: Fri Sep 19, 2008 6:29 pm
around 1980, fitted to the Metro
Rover 214 atm ....
Users browsing this forum: No registered users and 72 guests
