lock tab thingy
https://www.ausmini.com/forums/viewtopic.php?f=2&t=45945
Author:  carter [ Fri Sep 19, 2008 8:08 pm ]
Post subject:  lock tab thingy
g'day all well i was wandering with the locking tab thing that you bend over when you do up you flywheel nut all the bits on mine that you bend over are bocken off and at the moment i have it all pulled it apart so i need a new.....can you make your own out of a bit of sheet metal or somehting?????? cheers
Author:  simon k [ Fri Sep 19, 2008 8:20 pm ]
bin it and do the flywheel bolt up to 150lb/ft with some loctite 262 - the locktabs are a bad idea
Author:  carter [ Fri Sep 19, 2008 8:24 pm ]
bin it????loctite????what happens if i want to get it off again
Author:  sitnlo62 [ Fri Sep 19, 2008 8:27 pm ]
Sure you can if you can't wait for or get a comercially made one. Make sure you understand what is required for it to hold the nut from unscrewing before you start. Use the correct Gauge steel and start by putting the required hole for the flywheel bolt through it, then cut the disc out adout 1/2" larger in diameter than the flywheel washer. Fit the flywheel, washer, lock tab and bolt.Tighten to required tention then knock the tab down over the flat on the washer and bend it up onto the flat on the bolt.
Easy!
Dave
Author:  carter [ Fri Sep 19, 2008 8:30 pm ]
ok ill haev a go at making my own tomorrow..... thanks a lot guys
Author:  simon k [ Fri Sep 19, 2008 8:43 pm ]
don't do it....
Author:  1018cc [ Fri Sep 19, 2008 8:50 pm ]
Use loctite 262 on the threads. You can still break it, sure it needs a 1/2m long breaker bar but I would bin the lock tab.
Author:  dale 62 [ Fri Sep 19, 2008 9:11 pm ]
would you use the same loctite instead of all the other lock tabs through out the whole motor?
Author:  superSeven [ Sat Sep 20, 2008 9:07 pm ]
did you get your clutch problems sorted? :)
