It is currently Thu Jul 31, 2025 6:30 am
PostPosted: Sat Sep 20, 2008 5:41 pm
Hi all
(1) I have 2x hydro subframes
The stepped tower bolts are 5/16" unf at 1 end & 3/8 unf the other.
The 2 subframes are different. 1 has 5/16 the other has 3/8 in the head of the tower.
Which one is right, or it doesnt matter.
(2) Should I fit the studs to the towers & then fit the subframe to the car or fit the subframe then the studs?
(3) should I use the stepped studs or buy some bolts?
Thanks
Craig
1967 Morris Mini Deluxe
1927 Austin 7
PostPosted: Sat Sep 20, 2008 6:33 pm
I think the original size was 5/16. I'd say someone has stripped and retapped the holes.
PostPosted: Sat Sep 20, 2008 6:37 pm
All the hydros I have seen have beed 5/16 with a bolt.
Rubber subframes have been 3/8 with the stepped stud.
PostPosted: Sat Sep 20, 2008 8:57 pm
I have just stripped two front hydro subframes, one from 1972 the other from 1973, and one has the 3/8" and the other 5/16". One had studs, the other bolts so obviously at one stage they were manufactured so and NO they haven't been drilled and tapped.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Sun Sep 21, 2008 11:10 am
So, do you reckon it be better to use 3/8 bots or the stepped studs?
Craig
1927 Austin 7
PostPosted: Sun Sep 21, 2008 11:30 am
I would choose the best looking subframe. Check the displacer mounting lugs up inside the tower. If they are the same, I would use the studs as they may give more support.
Users browsing this forum: Bing [Bot] and 83 guests
