It is currently Sat Aug 02, 2025 8:26 pm
 Post subject: Opinions please
PostPosted: Mon Sep 22, 2008 11:33 am
I have 4x 2" gauages I wish to install in the Mini. I would like them to be unobtrusive as possible. Looking to put the oil press, water temp and volts together under the shelf to the right of the steering wheel using this
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=120304387562&ssPageName=STRK:MEWA:IT&ih=002
and the small taco in this to the right of the speedo on top of the shelf http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=110285588512&ssPageName=STRK:MEWA:IT&ih=001
What do you think? - Are the prices reasonable? Been hard to find anything really - non of the usual suspects have any sort of mounting brackets except pillar pods.
David L
PostPosted: Mon Sep 22, 2008 11:43 am
If you want to mount them under the parcel shelf, then a standard 90* style gauge bracket will work. They come in single, double and triple layouts and are pretty easy to get. Sure, they don't cover up the back of the gauge, but you won't be able to see that anyway.
I used to have gauges mounted under the dash rail to the right of the steering column and I wouldn't really recommend it as you had to go to effort to actually see the readout. I prefer my temp gauge in a prominent place, like right in front of me where I can't miss it. :wink:
