Note to self
https://www.ausmini.com/forums/viewtopic.php?f=2&t=45979
Author:  sgc [ Sat Sep 20, 2008 11:37 pm ]
Post subject:  Note to self
TIGHTEN UP YOUR FRIGGIN' WHEELNUTS YOU STUPID @#$@%^*!!!
Been working on the van to get it ready for a RWC, and had the front wheels off a few days ago to replace the shocks. Been driving it around a bit since, road testing engine tweaks.
Did the oil & filter tonight, along with the rocker clearances. Time for another test run, then. Out we go on my usual loop which normally takes in a stretch of the West Gate freeway, but tonight I figured I had learned enough and took a short cut back home.
Bloody glad I did -- slowly taking a 90* corner a K or two from home and the inside front wheel goes knockedy-knockedy and feeds back through the steering. Knew straight away what I'd (not) done, so pulled over and nearly all the wheel nuts on both front wheels had worked themselves nearly all the way off.
If I'd taken the freeway, I reckon I would have lost one (or both) front wheels at warp speed :shock: :shock:
I've used up my luck for this week I think.
Author:  blueminivan [ Sat Sep 20, 2008 11:42 pm ]
Lucky boy.
That could have ended in tears.
Author:  TurboOrangie [ Sun Sep 21, 2008 1:14 am ]
Also important to check your wheel nuts regularly for a while after replacing wheel studs. I put some longer wheel studs when I installed my white sport pack wheels and everything was torqued up with my torque wrench like I always do and I drove around for a couple days. Then one day I noticed a weird feeling and could only think of one thing that could cause it, I stopped the car and sure enough the wheel nuts had started to loosen off. So I tightened them up and drove home. I torqued them back up and carried the torque wrench around for while and checked them regularly.
Author:  mad-mk1 [ Sun Sep 21, 2008 2:17 am ]
i lost rear left at mallala a few weeks ago. i felt it so toodled towards pits, unfortunately it fell of on pit straight!
funnily enough another ausmini user who has the exact same wheel and tyre combo had loose nuts after his test drive. :?
Author:  Brown Clubman [ Sun Sep 21, 2008 2:36 pm ]
Post subject:  Re: Note to self
:shock: :shock: Scary stuff sgc!!!
Haven't seen you round mate ...... I live in Altona. Care to point me in the direction of some pics of your car so I can keep an eye out??
BC.
Author:  sgc [ Sun Sep 21, 2008 3:53 pm ]
BC.
Don't get into Altona in the Minis much, I usually shuttle between here and work in South Melbourne. Closest is the Kmart and Burson's in Altona North ;)
Here's the K:
This is the van (now minus stickers and racks):
Author:  1018cc [ Sun Sep 21, 2008 5:53 pm ]
You're a lucky boy Simon. I bet it will be something you regularly check now though! :shock: Glad nothing happened and you realised what it was before it was too late.
Author:  TUCK3r [ Sun Sep 21, 2008 6:02 pm ]
:oops: unleast it didnt come of at warped speed.on the bright side you probaly will never forget to check them a again.
TUCK3R
Author:  sgc [ Sun Sep 21, 2008 7:14 pm ]
I normally leave the car in the air until I do the nuts up, then the last thing I do when I put it down is tighten them up. No eye deer what happened this time around, brain fade most likely.. even though I tell myself not to forget it :roll:
You're right though, I'll find myself nipping up the wheel nuts every time I get in it for a while :lol:
Author:  pristic [ Sun Sep 21, 2008 7:52 pm ]
Ar - me thinks it may be this one... :lol:
http://www.ausmini.com/forums/viewtopic ... ight=wheel
Pete
Author:  chopchop [ Sun Sep 21, 2008 8:00 pm ]
lucky lucky. too nice a car to get damaged with the wheels falling off.
Author:  mad-mk1 [ Mon Sep 22, 2008 12:23 am ]
Pete
haha not quite! fellow saer actually!
