It is currently Sun Aug 10, 2025 11:22 pm
 Post subject: Coil Question
PostPosted: Mon Sep 22, 2008 11:46 am
Rover Cooper
Looking to put a nice shiney coil on the toy for summer, 8)
is there any special requirement for a coil for a Single point injected motor, on a 1275.. :roll:
what output do I need.?????????????????????? :wink:
or do I just use a normal coil.....are they all the same.
PostPosted: Mon Sep 22, 2008 10:11 pm
I'm not sure about the requirements for the injected motors...
However for a dizzy motor you want a 3 Ohm coil with as high an output voltage as you can find. A higher output coil will allow a larger spark plug gap providing you distributor, rotor, cap, leads and plugs are in good condition.
You can also use a 1.5 Ohm coil but then you need to add a ballast resistor in series so there isn't much point.
As for looks you can get a stainless steel cover the the coil fits into to make it 'look' like a shiny chrome one, then you can just make do with any old coil...
PostPosted: Mon Sep 22, 2008 10:53 pm
pretty sure you need a resistor type coil, the expert would be Steve (username Brickworx)
Noli Illegitimi Carborundum
PostPosted: Mon Sep 22, 2008 10:58 pm
This space for rent
Oh, I think Davo knows who Steve is :lol: :lol:
PostPosted: Mon Sep 22, 2008 11:02 pm
when I clicked on this thread I saw the username of the thread above or below who was a noob and didn't check. My mistake :oops:
 Post subject: Thanx
PostPosted: Tue Sep 23, 2008 3:36 pm
Rover Cooper
thanx gents, the idea of a chrome cover is very appealing to me, I think I will leave all well alone and just go for the cover. :wink: :wink: :wink:
 Post subject: Re: Thanx
PostPosted: Tue Sep 23, 2008 11:04 pm
These are nice chrome coils :)
PostPosted: Tue Sep 23, 2008 11:53 pm
I went through that site but couldn't work out which coil I needed for an SPI mini. I'd be pretty keen to buy one though...
Users browsing this forum: Bing [Bot] and 237 guests
