Coil Question https://www.ausmini.com/forums/viewtopic.php?f=2&t=46022 |
Author: | Davo111 [ Mon Sep 22, 2008 11:46 am ] |
Post subject: | Coil Question |
Looking to put a nice shiney coil on the toy for summer, ![]() is there any special requirement for a coil for a Single point injected motor, on a 1275.. ![]() what output do I need.?????????????????????? ![]() or do I just use a normal coil.....are they all the same. |
Author: | albino235 [ Mon Sep 22, 2008 10:11 pm ] |
I'm not sure about the requirements for the injected motors... However for a dizzy motor you want a 3 Ohm coil with as high an output voltage as you can find. A higher output coil will allow a larger spark plug gap providing you distributor, rotor, cap, leads and plugs are in good condition. You can also use a 1.5 Ohm coil but then you need to add a ballast resistor in series so there isn't much point. As for looks you can get a stainless steel cover the the coil fits into to make it 'look' like a shiny chrome one, then you can just make do with any old coil... |
Author: | benoz [ Mon Sep 22, 2008 10:53 pm ] |
pretty sure you need a resistor type coil, the expert would be Steve (username Brickworx) |
Author: | sgc [ Mon Sep 22, 2008 10:58 pm ] |
Oh, I think Davo knows who Steve is ![]() ![]() |
Author: | benoz [ Mon Sep 22, 2008 11:02 pm ] |
when I clicked on this thread I saw the username of the thread above or below who was a noob and didn't check. My mistake ![]() |
Author: | Davo111 [ Tue Sep 23, 2008 3:36 pm ] |
Post subject: | Thanx |
thanx gents, the idea of a chrome cover is very appealing to me, I think I will leave all well alone and just go for the cover. ![]() ![]() ![]() |
Author: | LS1380 [ Tue Sep 23, 2008 11:04 pm ] |
Post subject: | Re: Thanx |
Davo111 wrote: thanx gents, the idea of a chrome cover is very appealing to me, I think I will leave all well alone and just go for the cover.
![]() ![]() ![]() These are nice chrome coils ![]() ![]() |
Author: | benoz [ Tue Sep 23, 2008 11:53 pm ] |
I went through that site but couldn't work out which coil I needed for an SPI mini. I'd be pretty keen to buy one though... |
