It is currently Fri Aug 15, 2025 1:55 am
 Post subject: diff bearings
PostPosted: Wed Sep 24, 2008 6:43 pm
Just bought new diff bearings as old ones are stuffed,they are different to the origonial ones will they be ok or pull another diff and use good secondhand ones
PostPosted: Wed Sep 24, 2008 7:30 pm
The new ones are angular contact ball type not deep groove, they are marked `thrust' on one side, this goes outwards.
They fit the same, but note preload when shimmed should be .005", not .001" according to the old book.
