rounded steering wheel bolt.... https://www.ausmini.com/forums/viewtopic.php?f=2&t=46123 |
Page 1 of 2 |
Author: | mattsmadmini [ Thu Sep 25, 2008 7:40 pm ] |
Post subject: | rounded steering wheel bolt.... |
got a lowering bracket last week.... went to put it in yesterday.... but the bolt to un-do to put the bracket thing on (good english!) the nut part was rounded ![]() how do i undo it? ![]() |
Author: | sgc [ Thu Sep 25, 2008 7:43 pm ] |
If you can't get a pair of vice grips on it, take your dremel and cut it off ![]() |
Author: | mattsmadmini [ Thu Sep 25, 2008 7:45 pm ] |
note to self: Buy dremel. lol |
Author: | sgc [ Thu Sep 25, 2008 7:47 pm ] |
Yeah, I need me one of them too.. |
Author: | drmini in aust [ Thu Sep 25, 2008 7:53 pm ] |
Angle grind a flat or 2 on it then use vice grips. ![]() Or just cut it and the bolt off, then fit another. |
Author: | sgc [ Thu Sep 25, 2008 7:54 pm ] |
Oooh, the combination approach. I like it ![]() Doesn't change the fact I still need a dremel ![]() |
Author: | drmini in aust [ Thu Sep 25, 2008 7:56 pm ] |
sgc wrote: Oooh, the combination approach. I like it
![]() Doesn't change the fact I still need a dremel ![]() Dremels are toys, get thee a 1/4HP 24,000rpm die grinder.... ![]() |
Author: | mattsmadmini [ Thu Sep 25, 2008 8:02 pm ] |
cool.... well does anyone have a spare bolt then? |
Author: | simon k [ Thu Sep 25, 2008 8:04 pm ] |
mattsmadmini wrote: cool.... well does anyone have a spare bolt then?
the bolt shop does.... |
Author: | mattsmadmini [ Thu Sep 25, 2008 8:06 pm ] |
simon k wrote: mattsmadmini wrote: cool.... well does anyone have a spare bolt then? the bolt shop does.... duelly noted.... take it then it is not a mini specific thing then.... will try cut off 2moro and get another nut ![]() |
Author: | drmini in aust [ Thu Sep 25, 2008 8:08 pm ] |
simon k wrote: mattsmadmini wrote: cool.... well does anyone have a spare bolt then? the bolt shop does.... FFS don't put a metric bolt in it, it's supposed to be 5/16 UNF... ![]() |
Author: | 1310/71 [ Thu Sep 25, 2008 8:09 pm ] |
Weld a cheap socket onto it. |
Author: | mattsmadmini [ Thu Sep 25, 2008 8:26 pm ] |
1310/71 wrote: Weld a cheap socket onto it.
cant weld ![]() |
Author: | drmini in aust [ Thu Sep 25, 2008 8:29 pm ] |
mattsmadmini wrote: 1310/71 wrote: Weld a cheap socket onto it. cant weld ![]() Minis are like Valiants, their owners should learn to MIG weld, otherwise they are tied to the annual rust grind-bog-sand-spray routine every year. In NSW anyway. ![]() |
Author: | mattsmadmini [ Thu Sep 25, 2008 8:31 pm ] |
drmini in aust wrote: mattsmadmini wrote: 1310/71 wrote: Weld a cheap socket onto it. cant weld ![]() Minis are like Valiants, their owners should learn to MIG weld, otherwise they are tied to the annual rust grind-bog-sand-spray routine every year. In NSW anyway. ![]() i would if i had a MIG and someone to teach me... ![]() |
