It is currently Sat Jul 19, 2025 8:47 pm
 Post subject: Heater
PostPosted: Mon Nov 03, 2008 8:25 am
Hi,
I've decided that I'd like to put a heater in my 68 Deluxe. I was wondering if anyone could tell me what sort of heater should be in their and the best place to get one from.
Thanks
Dave
PostPosted: Mon Nov 03, 2008 8:33 am
Hi Dave,
I'm about to do the same in my 68 dlx..
I think the best option is the all-in-one rover mini heater.. as the heater control is attached to the heater..
if you fit a clubman heater, you need to fabricate a mount for the heater controls.
the only other option is the under bonnet heater which takes up A LOT of room under there! This is what I have, and is far from ideal! you also need to run a choke type cable to operate the vent.
depending on where you are located, talk to Steve at brickworx (SA), or Lindsay at minisplus (Vic), or Josh at miniimports (Vic), or I guess mini king (NSW)...
I know Lindsay has clubman heaters for ~$40.. and I know he has Rover heaters but unsure of the price.
Tim.
tim
PostPosted: Mon Nov 03, 2008 9:06 am
Thanks Tim,
My 68 is stock so I wanted to go the "original" option.
Sounds like the original one is the one that fits in the engine bay.
Dave
PostPosted: Mon Nov 03, 2008 9:07 am
I believe that was the standard option at the time.
where abouts are you located?
tim
PostPosted: Mon Nov 03, 2008 9:11 am
Im in Essendon at the moment but about to move to Glenroy.
How about you?
PostPosted: Mon Nov 03, 2008 9:25 am
Cooper S Mk1 or Mk11 heater will fit, you just need to make up two brackets to hang it on the firewall.
Daniel
PostPosted: Mon Nov 03, 2008 12:24 pm
The Minimatic under bonnet one was optional at the time on Deluxe and Mini K. Note it demists the RH screen vent only, using the metal duct and flap assembly that is welded in there already.
They work, the main problem is no airflow when car is stationary. :shock: I put a 3" Attwood bilge blower in the round duct hose from the heater. Noisy, but it works when I need it.
PostPosted: Mon Nov 03, 2008 3:36 pm
This is the one you might want
http://cgi.ebay.com.au/Mini-K-Fresh-Air ... 240%3A1318
