steel lower and upper dash rails https://www.ausmini.com/forums/viewtopic.php?f=2&t=4616 |
Author: | ausminis4u [ Mon Feb 07, 2005 9:25 am ] |
Post subject: | steel lower and upper dash rails |
hey guys just a quick q. can i cut the upper and lower dash rails out ? or are they part of the shells strength? i would rather cut them out completely thqan butcher them to fit the dash conversion in , thanks in advance , ben |
Author: | 13secmini [ Mon Feb 07, 2005 9:38 am ] |
ben i think they are there for strength as well as holding the dash and switches.. I left mine there and just put my starlet dash over them,, they came in handy as i could mount brackets of them to hold the toyota dash in place. Will the mira dash go over it? |
Author: | ausminis4u [ Mon Feb 07, 2005 11:26 am ] |
13secmini wrote: ben i think they are there for strength as well as holding the dash and switches..
I left mine there and just put my starlet dash over them,, they came in handy as i could mount brackets of them to hold the toyota dash in place. Will the mira dash go over it? the mira dash fowls the top rail in places, especialy where the central vents are , are u using the starlet heater and vent set up ? or mini heater still? also how is your column set up? would it be possible to just cut the top one out ? |
Author: | 13secmini [ Mon Feb 07, 2005 11:58 am ] |
no i scraped all the toyota heater, air con etc.. I also scrapped all the mini heater gear, i only got a little dicksmith computer fan hooked upto the dash for the demister ![]() There is enough heat coming from the engine bay to heat the cabin in winter and in summer its all windows down. Steering colum is standard mini, just got the lowering bracket in it. and a 70mm adjustable spacer on the boss kit to bring the wheel out further. I would not cut the entire top part of the dash out,, maybe just cut away the bits that are fowling, i cut alittle of the top bar for my cluster and it is fine. I think the bottom bar is more structural then then the top anyway. |
Author: | ausminis4u [ Mon Feb 07, 2005 12:08 pm ] |
13secmini wrote: no i scraped all the toyota heater, air con etc.. I also scrapped all the mini heater gear, i only got a little dicksmith computer fan hooked upto the dash for the demister how did u mount the starlet hardware onto the mini column? did it fit easily? how is the horn hooked up ?
Author: | 13secmini [ Mon Feb 07, 2005 12:18 pm ] |
the starlet stalk was a little to big for the mini column, so i just put a bit of pvc pipe in between the two and clamped it on. The horn is wired in normally, I used all the toyota wiring so just hooked it up. |
Author: | ausminis4u [ Mon Feb 07, 2005 12:22 pm ] |
13secmini wrote: the starlet stalk was a little to big for the mini column, so i just put a bit of pvc pipe in between the two and clamped it on. The horn is wired in normally, I used all the toyota wiring so just hooked it up. ok fair enough, did tou use the horn in the centre of the wheel?
Author: | 13secmini [ Mon Feb 07, 2005 12:40 pm ] |
yes i did to begin with but found out that my horn button was stuffed on my wheel, so i hooked it upto the water sprayer button on the end of the wiper arm ![]() Water sprayer button is now one of those nitrous trigger buttons on the right of the steering wheel near fog light switch. |
