It is currently Sun Jul 20, 2025 12:03 am
 Post subject: clubman indicator?
PostPosted: Wed Feb 09, 2005 10:47 am
do you guys know if a clubman indicator stalk and wiring will work on my morris?
i am bidding on one on ebay and was just wanting to know if it will work before i bid again. also could you say what a sensible price for a 2nd hand one would be so i don't overbid?
thanks alot
PostPosted: Wed Feb 09, 2005 11:09 am
I don't see why it shouldnt, they do the same things. you would just need to wire up all the stuff, and it should work like any switch should.
I need a new one, my mechanic said a new one retails for about $100 (!!!) so i suppose a decent second hand one would be about 50 bucks??? i dont know, just spectulation
78 Leyland Mini - Prince
PostPosted: Wed Feb 09, 2005 11:25 am
There was a post about this a bit earler, there are two different types of connectors one with one more wire than the other. Using a small screwdriver you can pop out all the brass connectors and put them in the appropriate plug (look at a wiring diagram).
The additional wire is for a flash / dimmer for your headlights and will work if you connect it to 12 volt power.
The original thread is at:
http://www.tziworld.com/ausmini/viewtopic.php?t=4532
The indicator stalks as far as I know aren't cheap last time I checked it was $90 -100 for a second hand one but I dare say they might have been trying to rip me off. :x
Roads need more corners
PostPosted: Wed Feb 09, 2005 11:52 am
clubman blinker stalks will fit on the column , but you will have to cut some wires( you cant swap plugs as there is no earlier plug) also later clubman arms used spade terminals where as mk1 arms used bullet connectors.
lookin for another clubby
PostPosted: Wed Feb 09, 2005 1:37 pm
thanks for that guys
i'll get bidding...
Users browsing this forum: Bing [Bot] and 84 guests
