Reverse lights
https://www.ausmini.com/forums/viewtopic.php?f=2&t=4641
Page 1 of 3
Author:  J_A_M [ Tue Feb 08, 2005 9:28 am ]
Post subject:  Reverse lights
The reverse lights on Pops don't come on. Is there a switch on or near the gearbox that controls them?
Author:  simon k [ Tue Feb 08, 2005 9:43 am ]
the switch is in the front of the gearbox on the passenger side, near the top..... if it's fitted
Author:  J_A_M [ Tue Feb 08, 2005 9:55 am ]
ok....do they break often? or could my prob be loose wires or even a fuse?
Author:  brickworx [ Tue Feb 08, 2005 10:25 am ]
Is it a rod change box...
if so it's on the gear lever selector box. next to the exhaust, most times the exhaust hits it or the wires have gone missing.
Author:  J_A_M [ Tue Feb 08, 2005 11:13 am ]
remote shift.
I'll have a squiz for loose wires.
Author:  ClubmanGT [ Wed Feb 09, 2005 3:18 am ]
Hey Anton,
I had the same problem. Not loose wires - the switch was coming apart!! It is held together by squashing the ali body over the plastic top. Take it out, squeeze it back tgether and tap (using a BFH) the folds down to stop any movement. Should start working again.
Gavin
Author:  Drekkus [ Wed Feb 09, 2005 6:38 am ]
The switch, if fitted, is on the front of the gearbox just under the oil filter.When mine didn't work I had to make up a new plunger to get the correct length for it to operate properly.Trial and error with a mutimeter.
Author:  J_A_M [ Wed Feb 09, 2005 7:29 am ]
ah...thanks guys....very helpfull info! I'll check it out tonight! :wink:
Author:  CRU17Y [ Wed Feb 09, 2005 4:54 pm ]
So how did you go with your reverse lights anton??
I am having a struggle to find mine, but if you get yours working let me know
Author:  poeee [ Wed Feb 09, 2005 4:59 pm ]
Easy way to see if the switch is fitted is check the rear lights. If the blinkers at the back have twin fillement (sp?) then it's got a reversing light switch. 8)
Author:  J_A_M [ Wed Feb 09, 2005 8:26 pm ]
hmmmm.......I had a good look this arvo. Nothing in the area mentioned......only the large hex head bolt for the reverse gear spring. I had a read of a few manuals, and all I could find was mention of a switch in the wiring diagram....can't see it on the car.
Like you say Poeee.......should there be one or did K's have it as an option....or not at all?
Anyone??
Author:  Morris 1100 [ Wed Feb 09, 2005 8:35 pm ]
They did not come with reversing lights till they had to!
The switch goes onto the the large hex head bolt for the reverse gear spring.
Author:  J_A_M [ Wed Feb 09, 2005 8:44 pm ]
so....if I go for a pink slip and the guy says..."reverse lights?" and I say "nope"......it will still pass?
Author:  drmini in aust [ Wed Feb 09, 2005 8:59 pm ]
No reverse lights on a `70 car. Mine passes every year, without.
same goes for no heater on early cars. :wink:
<edit> It's the 1098 Clubbie and Clubman GT that got the reversing lights first I think. Twin filaments in the rear blinkers.
Author:  J_A_M [ Wed Feb 09, 2005 9:08 pm ]
damn old cars...... :lol: ...had me stumped! I was fretting about this one, because it's the only thing I thought would knock me back for a pink slip.
Bring on rego for pops then! :wink:
Page 1 of 3 All times are UTC + 10 hours
