Temp gauge no worky :( https://www.ausmini.com/forums/viewtopic.php?f=2&t=46540 |
Author: | 1018cc [ Fri Oct 10, 2008 2:20 pm ] |
Post subject: | Temp gauge no worky :( |
It seems as though my temp gauge has bitten the dust. I would like to know if there is anything I can do to fix it before I take it to the local instrument repairer that I go to. It's a mechanical Smiths Water temp gauge from 30°C to 110°C. It has always underread from new but it always came to the same level (always went to 71° instead of 82° when the thermostat opened). Because it ALWAYS went to the same level and operated normally I got used to it as there was no apparent problem otherwise. One day I went for a drive in my car and it only went to 50°C maximum (it usually gets to 71°) ![]() I didn't work on my car for the week previous to that but, as careful as I try to be around it I probably kinked the line too far etc (some may even say I'm rough as guts ![]() So what I want to know is, is there anyway to fix it other than taking it to the local instrument repairer? I realise this is a long shot because I am assuming I have cracked the line and it is no longer pressurised - which is probably something I can't do at home ![]() If worst comes to the worst, has anyone got this done before and know an approximate $$$$$?? Cheers, Nick |
Author: | sitnlo62 [ Fri Oct 10, 2008 3:43 pm ] |
Hey Nick, Sounds like the Eather has leaked out. I will fix it, no problem, show you how too! Dave |
Author: | awdmoke [ Fri Oct 10, 2008 3:49 pm ] |
Let us all know, 'cause mine is going the same way ![]() |
Author: | 1018cc [ Fri Oct 10, 2008 4:04 pm ] |
sitnlo62 wrote: Hey Nick,
Sounds like the Eather has leaked out. I will fix it, no problem, show you how too! Dave It would be great if you could fix it for me ![]() ![]() I love learning stuff, thanks Dave! You're a champ. |
Author: | Mick [ Fri Oct 10, 2008 4:36 pm ] |
Ooooooh, this would be a how to I would be interested in... I hate coughing up the 150 bucks bill to get them working again... |
Author: | brett [ Fri Oct 10, 2008 10:58 pm ] |
mine is reading hot after a hard run and a bit of ideling I measured 68deg C on an inferred red sensor, but my guage was showing nearly boiling ( genuine S guage so its a guess) but def reads over half way all the time. Any ideas? I've fitted a New temp sender, and voltage regulator Cheers Brett |
Author: | BALLISTIC [ Sat Oct 11, 2008 8:30 am ] |
[quote="Mick"]Ooooooh, this would be a how to I would be interested in!![quote] Same here |
Author: | Mick [ Sat Oct 11, 2008 8:33 am ] |
I just watched a smiths twin oil/water temp guage go on ebay for nearly scrap value too... |
Author: | Morris 1100 [ Sat Oct 11, 2008 3:17 pm ] |
A while back I found a webpage that showed how to refill a temp gauge. Try Google. Edit, found it... http://www.ply33.com/Repair/tempgauge |
Author: | 1018cc [ Thu Oct 30, 2008 12:51 pm ] |
Just thought I would let everyone know how it went. It went fantastically. I need to get the camera back off the rents to do up a how to but it is coming! Here is a teaser: (sorry, taken with phone) ![]() Yep that's a saucepan of boiling water and the gauge reads 102°C. Closer than it has ever read! ![]() Because my gauge was so new (only about 2 months old total) there was no break in the actual line itself so Dave had a look at it (after I couldn't see where it was leaking from) and there was a REALLY SUSPECT solder just after the bulb. Dave pulled it apart and resoldered it and it has been working fine since. I will probably do up a how to on the weekend. Many thanks must go to Dave (sitnlo62) for doing this for me! He's a great guy and I loved being shown all his mini's and his other mini related gadgets he had there ![]() |
