It is currently Fri Aug 08, 2025 5:40 am
 Post subject: CV Boot
PostPosted: Sun Oct 12, 2008 2:12 pm
I've used cable ties to secure the boots on but the passenger side one keeps coming off.It seems the knobbly bit on the tie is too thick so when it turns it gets pushed off What else can I use which would give me the clearance.?
PostPosted: Sun Oct 12, 2008 2:46 pm
The metal clip that comes with some Boot Kits.
Like these ones form Mini Mania http://www.minimania.com/web/Item/GSV1053/InvDetail.cfm
Dicko
PostPosted: Sun Oct 12, 2008 2:55 pm
I have one of these straps and it still comes off.
I have to try again, does anyone sell them seperate?
also could tie wire be used?
blokeinamoke wrote:
PostPosted: Sun Oct 12, 2008 3:05 pm
Old skool uses tie wire.
Put it around at least twice to spread the load and make the tightening a little more progressive. Twist it off and fold it down.
Easier ways to do it these days, but stil a very good way of locking them down.
PostPosted: Sun Oct 12, 2008 4:55 pm
I'll add that by 'down' the wire should hang away from the normal direction of travel (being forwards).
The best thing to use is the later steel rings, they're 4-5mm wide and only 1mm thick.
No adjusting or tightening on them, they can just be tricky to install.
:D
PostPosted: Sun Oct 12, 2008 5:32 pm
I was thinking about try a tie wire. The strap looks easier but it also looks like I might still run into the same problem I'm having with a cable tie - the flat bit of the tie is ok ,its the connecting bit thats causing the problem.Its funny that its only a problem on one side.
