Steering Rack - Adjustable ? https://www.ausmini.com/forums/viewtopic.php?f=2&t=46678 |
Author: | Maxi23 [ Wed Oct 15, 2008 1:25 pm ] |
Post subject: | Steering Rack - Adjustable ? |
I had the front end of the mini looked at today by the mechanic at one of our servos, he showed me I had a heap of play in my LHF wheel. You can move it by hand probably 3 or 4mm in each direction (Direction they turn when being turned by steering wheel.). The play seems to be coming from inside the boot of the rack, all the ball joints and tie rod ends are fine. The rack doesnt move on the other side, just on the LHF side. Am I looking at a new rack ? (I don't want to reco this one.) Or can parts be repaired inside the boot with the rack still in the car ? If its a new rack, then I order one tommrow and it goes in next week. |
Author: | Maxi23 [ Wed Oct 15, 2008 1:47 pm ] |
After reading through 23 pages of search results on here, I now understand that the rack HAS to come out. |
Author: | peterw [ Wed Oct 15, 2008 2:50 pm ] |
It's most likely the ball joint at the inner end of the tie rod. It has shims and can be adjusted provided the joint is still OK. Don't necessarily need a reco rack. It would be a terrible job to attempt with the rack in the car. I'd be pulling it out. Pete |
Author: | John Smidt [ Wed Oct 15, 2008 2:59 pm ] |
My adivce is to get a recon Australian Rack, I think they are better than the new ones avail today |
Author: | My_Mini_Rocks [ Wed Oct 15, 2008 3:13 pm ] |
Quote: My adivce is to get a recon Australian Rack, I think they are better than the new ones avail today
I would agree with John on this IF it is the old tooling racks. We have a newer type rack- (some others may have it) but the tooling and quality is much better: ![]() |
Author: | Maxi23 [ Wed Oct 15, 2008 3:32 pm ] |
Yeah, I gave you guys a call (Minisport) this arvo asking if those ones fit the Rovers. I will more than likely place an order tomorrow. |
