Lower arm ball joints sheared https://www.ausmini.com/forums/viewtopic.php?f=2&t=46765 |
Author: | Ziegech [ Sat Oct 18, 2008 2:25 pm ] |
Post subject: | Lower arm ball joints sheared |
ill get some photos up when i get a chance bogged down with uni work but 50 metres from my house was stopped at a stop sign as u do slowly take off and the front left collapesed. turns out my front left ball joint came undone somehow. the tread on the hub half way down and about a quarter round snapped off? locking tabs all still in place? i was due to do all the grease nipples and regular check over this weekend too!!!!!!! soooo annoying but im extremely happy it happened there and i could limp it home semi back together. was planning on taking it out that night to with the partner, that wouldve been scary ive lost confidence in my car a bit now. need to do a thorough check over everything |
Author: | Mick [ Sat Oct 18, 2008 3:07 pm ] |
Good fun eh? If you're in need of a set of ball joints before the shops open on Monday, I have a new pair here (Point Cook). |
Author: | TheMiniMan [ Sat Oct 18, 2008 5:05 pm ] |
sounds like he needs a hub to me |
Author: | drmini in aust [ Sat Oct 18, 2008 5:27 pm ] |
TheMiniMan wrote: sounds like he needs a hub to me
The swivel hubs are just grey cast iron, brittle stuff, they do not take kindly to abuse. If a balljoint ever unscrews right off it often can break off a bunch of threads with it... This is the same reason they should never EVER be welded... ![]() |
Author: | Mick [ Sat Oct 18, 2008 5:35 pm ] |
Got one of them too I think in my scrap bin(if it's a drum brake hub you are after)... |
Author: | simon k [ Sat Oct 18, 2008 5:41 pm ] |
you're still on drums aren't you? if so, it sounds like your brick telling you to get your sh!t together |
Author: | TUCK3r [ Sat Oct 18, 2008 6:55 pm ] |
[ it sounds like your brick telling you to get your sh!t together[/quote] bahahaha luckily it happened close to home and not cornering. |
Author: | Ziegech [ Mon Oct 20, 2008 4:27 pm ] |
thanks for the offers of help everyone. had a spare hub and a few hours did a switch over to a new hub i had (was dads ![]() |
