Switched postive or switched earth?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=46824
Author:  smac [ Mon Oct 20, 2008 8:30 am ]
Post subject:  Switched postive or switched earth?
I'm doing a spot of re-wiring and have always wondered - is there any science behind whether a load should be switched on the negative or positive side? Over the years I've come across both methods on various makes and models...sometimes a mix on the one car. Thinking of things like wipers, horn etc. Anyone know for sure?
Author:  awdmoke [ Mon Oct 20, 2008 9:20 am ]
Makes no difference, but convention has it on the +ve
Author:  Mick [ Mon Oct 20, 2008 12:53 pm ]
It saves on copper, you don't need to supply a +ve feed top the switch and then a return wire to the horn/wiper etc.
In industry, wipe 10 cents off the each of a 5 million item stockline, and you will be feted around in a sedan chair with rose petals thrown out in front of you by naked virgins.
Author:  smac [ Mon Oct 20, 2008 1:05 pm ]
Rose petals eh? mmm.... :wink:
That's kinda what I was thinking. I have the horn sitting right next to a permenant positive, so makes sense to earth through the switch, whereas wipers it's easier to run a switched live across to them and earth there. Prolly a few other examples as well....
Thanks
Author:  Mick [ Mon Oct 20, 2008 1:49 pm ]
With high load devices (like wipers, lights etcetera) it is important to keep the length of copper the current travels on to a minimum. Calculations are made when designing the cars as to current carrying capacity, reliability and life expectancy of each component. They come down to simple numbers like: failures per million hours or failures per million operations.
So minimising copper length means minimising copper load (as you would need to increase the size of the wire to reduce copper losses) and reducing wiring complexity means lowering costs.
