It is currently Tue Jul 29, 2025 11:31 pm
 Post subject: dead again
PostPosted: Fri Oct 24, 2008 4:31 pm
I was on my home this afternoon when I had taken of from a set of light, I was in second with my foot to the floor when it started going POP POP POP POP POP POP from the carby, no power and I could only get up to 40km in 4 gear, I limped back to a mechanic, he won't be able to look at it till monday :cry:
So any ideas, hoping for something wrong with the carby but might be something wrong with the head.
"When you're in it up to your ears....it pays to keep your mouth shut!"
PostPosted: Fri Oct 24, 2008 5:19 pm
something similar happened to me once... was a broken rocker shaft... but i imagine it could be anything in that area including broken valve spring, stuck valve?
just guesses really...
tim
PostPosted: Fri Oct 24, 2008 5:28 pm
that happened to me once.. and it was foam from the air filter that had fallen into pieces and into teh carbie... oops. :oops:
PostPosted: Fri Oct 24, 2008 7:58 pm
yepp definatly air filter, run it with out a filter and see how it goes exact same thing happened to me. soo easy to give a try and could save u soo much money and time.
PostPosted: Fri Oct 24, 2008 9:37 pm
Sounds like when my car blew a head gasket... If it runs normally for a few seconds after startup then goes back to that state, it probably is.
PostPosted: Sat Oct 25, 2008 12:00 am
what type of carby is it :?: weber, su, etc?
PostPosted: Sat Oct 25, 2008 5:29 am
could be a number of things...did it sound like a VW if so head gasket gone. or it could be as simple as the fuel filter
PostPosted: Sat Oct 25, 2008 8:56 am
Hi thanks for your replies,
sounded like a VW
it's a 998 with a single 1.5 SU,
how much will a new head gasket cost?
ATM I have a crappy head 12A1456 Should I look at getting a 202 or 295?
PostPosted: Sat Oct 25, 2008 3:44 pm
something similar happened to me once - was the distributor it sliped around and threw the timing out -took FOREVER to figure out
PostPosted: Mon Oct 27, 2008 5:14 pm
Lost compression in No.3 + 4 cylinders, I decided to replace the entire head with a 12G202 head, now when I'm ready to do some work on my block i'll have the right head to start with.
thanks to mini spares in padstow
PostPosted: Mon Oct 27, 2008 6:49 pm
similar thing happened to me due to over ajusted rocker gear,
snaped an exhaust push rod on cyl 2, identified the problem on the side of the road disconnected the lead and drove home to fix it on 3 cylinders. struggled to reach 60 in forth.
Users browsing this forum: Barkfast, Bing [Bot] and 110 guests
