It is currently Thu Aug 21, 2025 1:18 am
 Post subject: Metric and Imperial ?!
PostPosted: Tue Oct 21, 2008 9:04 pm
Am doing up a 63 Mini.
Fitting a Rover front subframe/engine/gearbox/brakes.
Currently have everything out of the engine bay and sprayed the new colour.
Made the obvious decision to replace the old brake and fuel lines whilst I can get to
them easily.
Just realised that the brake line coming from the sub frame is actually metric.
No prob.. I will just have a new line made from the sub frame T piece, to be metric
on one end and imperial on the other.
Then I thought I'd check the Rover clutch slave cylinder.. to find that it is imperial.
Why would they use both metric and imperial??? :x
To have a true objective opinion on all things motoring, one must experience a variety of configerations and combinations on a regular basis in an effort to not form an excessive attachment... Oh who am I kidding...
PostPosted: Tue Oct 21, 2008 9:13 pm
I bet most new fuel line made in the EU now is metric.
As for the slave cylinder, they have always been Imperial on Minis.
A few other metrics in a Mini-
Flywheel puller bolt holes (Verto clutch only)
Brake pipe connections to FAM valve on bulkhead (late Clubby)
