Metric and Imperial ?!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=46871
Author:  Speed [ Tue Oct 21, 2008 9:04 pm ]
Post subject:  Metric and Imperial ?!
Am doing up a 63 Mini.
Fitting a Rover front subframe/engine/gearbox/brakes.
Currently have everything out of the engine bay and sprayed the new colour.
Made the obvious decision to replace the old brake and fuel lines whilst I can get to
them easily.
Just realised that the brake line coming from the sub frame is actually metric.
No prob.. I will just have a new line made from the sub frame T piece, to be metric
on one end and imperial on the other.
Then I thought I'd check the Rover clutch slave cylinder.. to find that it is imperial.
Why would they use both metric and imperial??? :x
Author:  drmini in aust [ Tue Oct 21, 2008 9:13 pm ]
I bet most new fuel line made in the EU now is metric.
As for the slave cylinder, they have always been Imperial on Minis.
A few other metrics in a Mini-
Flywheel puller bolt holes (Verto clutch only)
Brake pipe connections to FAM valve on bulkhead (late Clubby)
