Timing chain tensioner question. https://www.ausmini.com/forums/viewtopic.php?f=2&t=46900 |
Author: | Kennomini [ Wed Oct 22, 2008 7:49 pm ] |
Post subject: | Timing chain tensioner question. |
Is their a proper way to set the tensioner on an A+ 1275 or do you just simply do it by feel? |
Author: | BALLISTIC [ Wed Oct 22, 2008 7:54 pm ] |
![]() ![]() Personal preference |
Author: | drmini in aust [ Wed Oct 22, 2008 8:08 pm ] |
What he said- ^^^ ![]() Some people fit a duplex chain and keep the A+ tensioner too. It's not designed for a duplex but apparently works, sort-of. I've never felt the need.. ![]() Note that most chains now are poorly made (compared to the Renolds UK chain of yesteryear)- they are loose when new. The exception is the Jwis endless chain (made in Germany, around $60), Rolon chain is pretty good too. |
Author: | justminis [ Wed Oct 22, 2008 8:20 pm ] |
Post subject: | Re: Timing chain tensioner question. |
Kennomini wrote: Is their a proper way to set the tensioner on an A+ 1275 or do you just simply do it by feel?
Yes, by feel, enough to take any slack out of the chain, then just a little tension. I have been running the A+ tensioner on my race engines for years now without any dramas. These A series blocks have been line bored so the distance between crank and camshaft has been altered and the tensioner takes out any slack. |
Author: | Kennomini [ Wed Oct 22, 2008 9:12 pm ] |
Thanks, all done now. I used a Rolon single row chain, permertight on the gasket and loctight on the bolts, should all be good fingers crossed ![]() |
