It is currently Sat Aug 09, 2025 7:38 pm
 Post subject: camshafts
PostPosted: Wed Oct 22, 2008 8:30 pm
how much difference between kent286 and re13
PostPosted: Wed Oct 22, 2008 8:43 pm
High heel ninja
Ring Graham Russell and ask him.
Doogie
PostPosted: Wed Oct 22, 2008 9:59 pm
RE13 gives more power than a 286 IMO, it's better in traffic too.
I love my RE282 better than both, but sadly these are now NLA. :cry:
PostPosted: Wed Oct 22, 2008 10:15 pm
why??
Cant you just provide him a cam and he grind it to that specification??
 Post subject: Camshafts
PostPosted: Wed Oct 22, 2008 10:35 pm
He,s right if you get the specifications a good cam grinder can give you the cam you want for less than $150. If you buy one "off the shelf" it will cost you $400+. I had a look at the Kent Cams website and the MD274SP looks like a great grind for a 1098, nice wide powerband. 8)
PostPosted: Wed Oct 22, 2008 11:28 pm
Resident Test Pilot
You have hidden the blank so no-one else can get one havn't you Kev !
PostPosted: Thu Oct 23, 2008 5:46 am
Sadly, the 282 cam grind master got lost a year or so ago when sent to Melbourne for hardening. It has never been found.
Cost to get another master generated in USA is now prohibitive.
If a fresly ground 282 cam existed, a master could be made from it- however, accuracy would not be as good as a new master.
Only about 4 of these 282 cams were made- 3 are in use and one was trashed when a motor blew.
However, Graham has further developed the RE13 since- if you want a little more top end than the standard RE13, he can oblige. :wink:
PostPosted: Thu Oct 23, 2008 6:41 am
Whose motor blew? Was that Jai's one? Or has willy lived up to all expectations :(
I know its not mine and its not yours :wink:
PostPosted: Thu Oct 23, 2008 7:47 am
Mine hasn't had the chance to have anything go wrong! :oops:
Since the drags in October it has been sitting in the shed... The body shell is STILL at the paint shop.
Mick, what torque is yours making?
PostPosted: Thu Oct 23, 2008 6:18 pm
Mick, yeah it was Jai- apparently he lent the car to someone and they blew the motor up comprehensively. He was "Not Happy, Jan".
Jai posted pics here of the blowup at the time, but I dunno where the thread is. :wink:
PostPosted: Thu Oct 23, 2008 6:31 pm
You mean this one :shock:
PostPosted: Thu Oct 23, 2008 6:37 pm
Yep, nice job there, ay. :lol:
Wonder what crank it was, I can't see the part numbers...
PostPosted: Thu Oct 23, 2008 7:19 pm
minicranks wrote:
Kev the crank is an A+ rolled radius crank that was crack tested (electromagnetically), Big journal and std std bearings. all new down stairs.
But as luck would have i have his car so i have some ransom to hold onto, but it was the only south african block in the country, it was also an A+ gear box with the 3bolt main shaft bearing and larger idler gear.
PostPosted: Fri Oct 24, 2008 6:25 am
Thanks for that.
This has to be the best busted crank and block job I've seen (and I've seen a few...) :lol:
PostPosted: Fri Oct 24, 2008 9:37 am
Looks like the crank wanted to look after the oil filter... :shock:
Damn! But hey! Looks quite fixble, compared to this:
:lol:
Jan
