camshafts https://www.ausmini.com/forums/viewtopic.php?f=2&t=46902 |
Page 1 of 2 |
Author: | Goldbrocade_62 [ Wed Oct 22, 2008 8:30 pm ] |
Post subject: | camshafts |
how much difference between kent286 and re13 |
Author: | doogie [ Wed Oct 22, 2008 8:43 pm ] |
Ring Graham Russell and ask him. Doogie |
Author: | drmini in aust [ Wed Oct 22, 2008 9:59 pm ] |
RE13 gives more power than a 286 IMO, it's better in traffic too. I love my RE282 better than both, but sadly these are now NLA. ![]() |
Author: | Bubbacluby [ Wed Oct 22, 2008 10:15 pm ] |
drmini in aust wrote: I love my RE282 better than both, but sadly these are now NLA.
![]() why?? Cant you just provide him a cam and he grind it to that specification?? |
Author: | 74snail [ Wed Oct 22, 2008 10:35 pm ] |
Post subject: | Camshafts |
He,s right if you get the specifications a good cam grinder can give you the cam you want for less than $150. If you buy one "off the shelf" it will cost you $400+. I had a look at the Kent Cams website and the MD274SP looks like a great grind for a 1098, nice wide powerband. ![]() |
Author: | matt850 [ Wed Oct 22, 2008 11:28 pm ] |
drmini in aust wrote: RE13 gives more power than a 286 IMO, it's better in traffic too.
I love my RE282 better than both, but sadly these are now NLA. ![]() You have hidden the blank so no-one else can get one havn't you Kev ! |
Author: | drmini in aust [ Thu Oct 23, 2008 5:46 am ] |
matt850 wrote: drmini in aust wrote: RE13 gives more power than a 286 IMO, it's better in traffic too. I love my RE282 better than both, but sadly these are now NLA. ![]() You have hidden the blank so no-one else can get one havn't you Kev ! Sadly, the 282 cam grind master got lost a year or so ago when sent to Melbourne for hardening. It has never been found. Cost to get another master generated in USA is now prohibitive. If a fresly ground 282 cam existed, a master could be made from it- however, accuracy would not be as good as a new master. Only about 4 of these 282 cams were made- 3 are in use and one was trashed when a motor blew. However, Graham has further developed the RE13 since- if you want a little more top end than the standard RE13, he can oblige. ![]() |
Author: | mickmini [ Thu Oct 23, 2008 6:41 am ] |
drmini in aust wrote: I love my RE282 better than both, but sadly these are now NLA. :cry Only about 4 of these 282 cams were made- 3 are in use and one was trashed when a motor blew. Whose motor blew? Was that Jai's one? Or has willy lived up to all expectations ![]() I know its not mine and its not yours ![]() |
Author: | willy [ Thu Oct 23, 2008 7:47 am ] |
Mine hasn't had the chance to have anything go wrong! ![]() Since the drags in October it has been sitting in the shed... The body shell is STILL at the paint shop. Mick, what torque is yours making? |
Author: | drmini in aust [ Thu Oct 23, 2008 6:18 pm ] |
Mick, yeah it was Jai- apparently he lent the car to someone and they blew the motor up comprehensively. He was "Not Happy, Jan". Jai posted pics here of the blowup at the time, but I dunno where the thread is. ![]() |
Author: | EST-071 [ Thu Oct 23, 2008 6:31 pm ] |
drmini in aust wrote: Mick, yeah it was Jai- apparently he lent the car to someone and they blew the motor up comprehensively. He was "Not Happy, Jan".
Jai posted pics here of the blowup at the time, but I dunno where the thread is. ![]() You mean this one ![]() ![]() ![]() ![]() ![]() |
Author: | drmini in aust [ Thu Oct 23, 2008 6:37 pm ] |
Yep, nice job there, ay. ![]() Wonder what crank it was, I can't see the part numbers... |
Author: | EST-071 [ Thu Oct 23, 2008 7:19 pm ] |
minicranks wrote: Kev the crank is an A+ rolled radius crank that was crack tested (electromagnetically), Big journal and std std bearings. all new down stairs.
But as luck would have i have his car so i have some ransom to hold onto, but it was the only south african block in the country, it was also an A+ gear box with the 3bolt main shaft bearing and larger idler gear. |
Author: | drmini in aust [ Fri Oct 24, 2008 6:25 am ] |
Thanks for that. This has to be the best busted crank and block job I've seen (and I've seen a few...) ![]() |
Author: | Asphalt [ Fri Oct 24, 2008 9:37 am ] |
Looks like the crank wanted to look after the oil filter... ![]() Damn! But hey! Looks quite fixble, compared to this: ![]() ![]() Cheers, Jan |
