It is currently Sun Aug 17, 2025 4:07 am
PostPosted: Fri Oct 24, 2008 3:05 pm
Hi there
I am fine tuning my sc12 setup at the moment and was wondering if anyone could recommend a Needle spec for the HIF6. I am running 6psi to 10psi (from 2K to 5K rpm). 8.5:1 Cr pistons .12g940 head standard. MSD boost ignition retard module on Pulsar dizzy.
I am currently running a BCJ needle that looks original (un filed) and whilst performance is pretty good, fuel economy is shocking. It is definately running a little rich down low and at midrange.
I am getting a wideband air fuel gauge soon and assume that I will need to do some major needle filing/profiling but I am just curious as to what needle others are using. (The HIF6 is pretty much the same as HIF44)
Cheers :D
Rick
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Fri Oct 24, 2008 3:34 pm
hi mini 66
im running a similiar setup with electronic dizzy and hif44 on a 1275 ex mg metro a+ block tuning by urself will be very difficult without the air/fuel reading to help make a decision on the needle. i handed mine to link automotive for a gas analyze tune but im not sure on the needle ill let u know next chance i get but it will only be a ball park not precise. if im not mistaken its fairly individual to the setup so there will still be some fiddling yet
Enjoy Chris ;)
PostPosted: Fri Oct 24, 2008 5:11 pm
Hi Ziegech
Thanks for that. I can't wait until my wideband air fuel kit comes. It should be fun profiling needles until I get it spot on.
I don't trust the dyno tuners here in Coffs Harbour.
What sort of manifold are you runnind the sc12 off?
Ford DF LTD - 5Ltr
PostPosted: Sat Oct 25, 2008 10:15 pm
my inlet setup is bens sc12 set up or user 92
http://www.ausmini.com/forums/viewtopic ... c&start=15
ill get around to the needle soon sorry really busy at the moment
Enjoy Chris ;)
PostPosted: Sun Oct 26, 2008 12:32 pm
No worries mate - No hurry
My inlet manifold is home made - see link
http://www.ausmini.com/forums/viewtopic.php?t=46795
Ford DF LTD - 5Ltr
Users browsing this forum: No registered users and 399 guests
