It is currently Thu Aug 14, 2025 8:13 pm
 Post subject: Elec Dizzy...Why
PostPosted: Sat Oct 25, 2008 10:56 am
Rover Cooper
whats the advantage of fitting an electronic dizzy to an A+ engine, how much would it cost, and is there anyone west of Melbourne that can fit one properly.
PostPosted: Sat Oct 25, 2008 11:07 am
bascically... smoother running - better idle, no adjustment (point gap), not affected by moisture...
cost varies depending on system used... there's the flame thrower, aldon, petronics, and recently found a cheap one from the uk..
tim
PostPosted: Sat Oct 25, 2008 11:14 am
I don't think there is any advantage for you Davo, your car should have it.
Most A+ units do.
:D
PostPosted: Sat Oct 25, 2008 11:15 am
Davo, your EFI car should already have one. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Oct 25, 2008 11:18 am
They stay in tune longer, and are more resistant to wet weather.
There are a few options here-
Lucas electronic
Nissan Pulsar (fit an A+ drive dog on)
Pertronix Flamethrower (see link below)
Or, fit a Pertronix ignitor to the dizzy you already have.
http://www.vintageperformance.com/retro ... /lucas.htm
PostPosted: Sat Oct 25, 2008 12:52 pm
The Mini King
Mini King has one new electronic distributor with the module fitted to the side of distributor Part Number AUU1086 Lucas Number 42635J , If this is of any help
 Post subject: Re: Elec Dizzy...Why
PostPosted: Sat Oct 25, 2008 12:59 pm
Less radio interference 8)
 Post subject: Im a Dizzy
PostPosted: Sat Oct 25, 2008 1:04 pm
Rover Cooper
Just shows how much I know about the cars,
:wink: :wink:
I will have to Give Steve a ring and find out what type I have on the car, is there and easy way of just looking and telling what type you have fitted. :oops: :oops:
PostPosted: Sat Oct 25, 2008 1:07 pm
Davo, if you open up the dizzy and don't see any points inside, you've got an electronic dizzy. 8)
PostPosted: Sat Oct 25, 2008 1:10 pm
Davo if you're talking about your SPI mini.....it's electronic.
It's also different to a non-injection unit as well, it has even less stuff inside!
PostPosted: Sat Oct 25, 2008 1:11 pm
Rover Cooper
Open up the Dizzy, I can,t even see the top of it, that will be a job for " SUPER MECHANIC, when I get a chance, Grill, A/C Hose, A/C Radiator, HJorn, all have to be moved.... :oops: :oops:
Will get around to it shortly. :oops:
PostPosted: Sat Oct 25, 2008 3:12 pm
I only have to get the grille off mine to get to the dizzy. Does your engine bay basically look like this?
PostPosted: Sat Oct 25, 2008 3:27 pm
contact Lindsey at minis plus mine just cost me $250.00 plus a few dollars for some other work.goes much better :D
PostPosted: Sat Oct 25, 2008 4:57 pm
Rover Cooper
Thats the problem, where your ECU is thats where my A/C Radiator goes and it takes up a crap load of room at the front of the Dissy...
My ECU is where your A/C Radiatior is, so their opposite....
Make sence...???????
PostPosted: Sat Oct 25, 2008 5:01 pm
DAVO.....YOUR CAR HAS AN ELECTRONIC DIZZY!
:D
Users browsing this forum: Barkfast, Bing [Bot], TartanRed and 166 guests
