Hi there
I am fine tuning my sc12 setup at the moment and was wondering if anyone could recommend a Needle spec for the HIF6. I am running 6psi to 10psi (from 2K to 5K rpm). 8.5:1 Cr pistons .12g940 head standard. MSD boost ignition retard module on Pulsar dizzy.
I am currently running a BCJ needle that looks original (un filed) and whilst performance is pretty good, fuel economy is shocking. It is definately running a little rich down low and at midrange.
I am getting a wideband air fuel gauge soon and assume that I will need to do some major needle filing/profiling but I am just curious as to what needle others are using. (The HIF6 is pretty much the same as HIF44)
Rick
