It is currently Wed Aug 13, 2025 2:31 pm
PostPosted: Sat Oct 25, 2008 5:33 pm
Hiya
As the suject states
Do I just hit it with a BFH tho did try that but only broke the alloy trumpet.going to put Hi LOs in.
Any ideas would be great.maybe good for how to thread
Baxter
PostPosted: Sat Oct 25, 2008 5:42 pm
Brute force, I just stripped down a front subby today and smashed both trumpets trying to seperate them from the rubber cones.........BUGGER........replacing them with hilo's anyway but WD40.......
Mini, its in my blood........
PostPosted: Sat Oct 25, 2008 5:43 pm
Soak overnight with WD40.
Hit edge of trumpet down from rubber with a BFH and chisel, work your way around.
PostPosted: Sat Oct 25, 2008 6:18 pm
thx guyz will give it ago
PostPosted: Sat Oct 25, 2008 8:08 pm
do you mean remove the knuckle joint from the trumpet??
I got a big screw driver and put it in the centre of th trumpet and then belted screwdriver with hammer and freed the knuckle
I never had a problem with removing donut from trumpet
PostPosted: Sat Oct 25, 2008 9:41 pm
Like Doc said for the donut end soak it in WD40 and use a chisel or a flat screwdriver to work them apart. With the knuckles I sprayed the WD40 down the trumpet and let that soak for a night then I used a piece of steel rod with one end on the ground I slammed the trumpet down over it until the knuckle comes out the top.
WD40 is your friend :wink:
Users browsing this forum: No registered users and 202 guests
