Whats the 3mm hole in the water pump for?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=46969
Author:  Harley [ Sat Oct 25, 2008 3:02 pm ]
Post subject:  Whats the 3mm hole in the water pump for?
It's not threaded, so not for a grease fitting.
Should I block it up or anything?
What is it?
:D
Author:  TheMiniMan [ Sat Oct 25, 2008 3:06 pm ]
It`s a bleed hole to let the water out for when the seal wears out, don`t block it up, just leave it & when you see water comming from there, then you know the seal is buggered
Author:  Harley [ Sat Oct 25, 2008 3:09 pm ]
But surely half the reason for the seal to wear is because contaminents are getting in through that hole and causing abrasion on the inside?
Author:  TheMiniMan [ Sat Oct 25, 2008 3:30 pm ]
nah, the wear occurs on the other side of the seal,,, it runs against the back of the impella, so basically no grit can get to that surfasce through that little hole
If the hole wasn`t there, then what happens is the bearing gets more water through it (than it would with the hole) & therfore causes even more rapid destruction of the bearing than it allready would,,, so , if/when the seal gives up, they (the manufactures of water pumps) allow the water to piss out through that hole rather than have all the water pass through the bearing wrecking it more quickly & making it harder to see where the water is comming from,,, the little hole leaves a nice easilly view-able trace of rusty yukky water marks comming from it so is an easy "tell-tale" that the water pump is rooted
Author:  Kennomini [ Sat Oct 25, 2008 9:48 pm ]
It took me a month and a radiator swap to figure out the water pump was leaking :oops:
At least I hope it's that as I'm 3/4 of the way swapping it :roll: , and it's good to know what that hole is.
