Vac / breather Hose question https://www.ausmini.com/forums/viewtopic.php?f=2&t=46970 |
Author: | mini-dunger [ Sat Oct 25, 2008 3:19 pm ] |
Post subject: | Vac / breather Hose question |
HI all I have the vac hose from the SU connected to the pulsar dizzy. I have a charcoal cannister with 2 holes in top, a big one and a small one. The little one is connected to the fuel tank. Should the fatter hole on top be connected to the tappet chest breather? as I am pretty sure the rocket cover gets connected to the air cleaner? Or should I just connect the rocket cover to the air cleaner and then just put a hose on the cannister and just tuck it away somwhere? any ideas? thanks all |
Author: | Harley [ Sat Oct 25, 2008 3:22 pm ] |
I have my rocker cover going to the air cleaner, and the charcoal thingy did plug into the carby, but it's currently not connected as the car wouldn't idle. |
Author: | mini-dunger [ Sat Oct 25, 2008 6:09 pm ] |
ok mate thanks I will just rig a fake hose and stick it somewhere out of the way |
Author: | drmini in aust [ Sat Oct 25, 2008 6:24 pm ] |
With an RE13 cam (or any sports cam really), the vac line to the dizzy does SFA. There is insuffient vacuum, cruising at part throttle to make it work. So says the man who grinds the cams... ![]() |
