How do I remove trumpets from rubber cones? https://www.ausmini.com/forums/viewtopic.php?f=2&t=46974 |
Author: | Baxters850 [ Sat Oct 25, 2008 5:33 pm ] |
Post subject: | How do I remove trumpets from rubber cones? |
Hiya As the suject states Do I just hit it with a BFH tho did try that but only broke the alloy trumpet.going to put Hi LOs in. Any ideas would be great.maybe good for how to thread cheers Baxter |
Author: | justincase42 [ Sat Oct 25, 2008 5:42 pm ] |
Brute force, I just stripped down a front subby today and smashed both trumpets trying to seperate them from the rubber cones.........BUGGER........replacing them with hilo's anyway but WD40....... |
Author: | drmini in aust [ Sat Oct 25, 2008 5:43 pm ] |
Soak overnight with WD40. Hit edge of trumpet down from rubber with a BFH and chisel, work your way around. |
Author: | Baxters850 [ Sat Oct 25, 2008 6:18 pm ] |
thx guyz will give it ago |
Author: | Bubbacluby [ Sat Oct 25, 2008 8:08 pm ] |
do you mean remove the knuckle joint from the trumpet?? I got a big screw driver and put it in the centre of th trumpet and then belted screwdriver with hammer and freed the knuckle I never had a problem with removing donut from trumpet |
Author: | Kennomini [ Sat Oct 25, 2008 9:41 pm ] |
Like Doc said for the donut end soak it in WD40 and use a chisel or a flat screwdriver to work them apart. With the knuckles I sprayed the WD40 down the trumpet and let that soak for a night then I used a piece of steel rod with one end on the ground I slammed the trumpet down over it until the knuckle comes out the top. WD40 is your friend ![]() |
