It is currently Mon Aug 18, 2025 1:01 am
 Post subject: Booster hookup question
PostPosted: Sun Oct 26, 2008 2:08 pm
Lots of pics I've seen of booster sets ups I can't see a 'non-return' valve in the vacuum hose, yet I read - all be it on sellers sites - that one is essential. Does every one have one or do you get by without?
PostPosted: Sun Oct 26, 2008 2:26 pm
The elbow /connection fitted to the bellows on the booster is the one way valve. It should be able to hold a charge after the engine has been turned off.
PostPosted: Sun Oct 26, 2008 2:39 pm
They all have them. Like Mick said they are in the elbow fitting.
If you didn't have a non-return valve you would not have vacuum in the brakes when you opened the throttle!
Maximum vacuum is pulled when you are coasting along on closed throttle. So it stores the vacuum till you need it.
In some cases with some cars (though not usually with Minis) you can actually run out of vacuum depending on the cam and the way it is driven. XU1 Toranas had a double diaphram booster (a bigger capacity booster) and HO Falcons had a vacuum tank to store more vacuum. Ford made these vacuum tanks as an option for towing packs.
PostPosted: Sun Oct 26, 2008 2:57 pm
Gottcha - re-read the blurb at it says "essential if you don't have the U shaped connection"
PostPosted: Sun Oct 26, 2008 9:26 pm
I know three different valves: conecting directely to the manifold (Cooper S), valves in the middle of the hose (Rover standart from '89 on) and like Mick said.
Jan
Users browsing this forum: No registered users and 300 guests
