Rear Bump stops/front shockers? https://www.ausmini.com/forums/viewtopic.php?f=2&t=47011 |
Page 1 of 2 |
Author: | Klubman [ Sun Oct 26, 2008 4:37 pm ] |
Post subject: | Rear Bump stops/front shockers? |
Hi All For hydro car which is the best to try first? Competion Bump stops on the rear or shockers on the front? Nigel |
Author: | Ziegech [ Sun Oct 26, 2008 5:17 pm ] |
ive been told that the rear bump stops are a better option, they are also cheaper so probably best to try first and if u need a little more to try the shockers. im looking at comp bump stops all around and lowering my hydro pressure |
Author: | TheMiniMan [ Sun Oct 26, 2008 5:31 pm ] |
do BOTH |
Author: | Klubman [ Sun Oct 26, 2008 5:43 pm ] |
I would like to do both but I think the guy doing all the work would like to see the end of the project. I keep adding to the wishlist and I was just hoping to not ask for tooo much. |
Author: | Mick [ Sun Oct 26, 2008 5:55 pm ] |
Love the shocks, love the bumpstops too....rear bumpstops are very fast to fit however, and cheap. |
Author: | aaron [ Sun Oct 26, 2008 7:15 pm ] |
No matter how much you play with suspension on a mini, if you go into a corner too hard it will still do this........ ![]() ![]() ![]() ![]() Wet ![]() Dry |
Author: | Klubman [ Sun Oct 26, 2008 7:37 pm ] |
I was not thinking of cornering, just want to reduce bonnet lift on take off. |
Author: | Morris 1100 [ Sun Oct 26, 2008 7:40 pm ] |
Fit an 850. ![]() Just the rear bump stops will do for starters. |
Author: | gafmo [ Sun Oct 26, 2008 7:48 pm ] |
Hydro Rear Compotion Stops ![]() |
Author: | Klubman [ Sun Oct 26, 2008 7:51 pm ] |
Having just changed from 998 to 1310, to ask for an 850 may not go down too well. I think I will request the bump stops and perhaps he will do both. |
Author: | 1310/71 [ Sun Oct 26, 2008 9:24 pm ] |
aaron wrote: No matter how much you play with suspension on a mini, if you go into a corner too hard it will still do this........
![]() ![]() ![]() ![]() That's just the hydro overcompensating for the fat basta#d in the drivers seat ![]() KB |
Author: | mattsmadmini [ Sun Oct 26, 2008 10:43 pm ] |
fit both mate, comp stops in the back will be great for torque transfer and keep the arse 'up' as for the shocks up front, anything will do, a pair of cheap oil-filled ones will do the trick, no point spending hundreds of bucks on adjustable things if the car is Hydro... |
Author: | drmini in aust [ Mon Oct 27, 2008 6:50 am ] |
Comp rear bumpstops also help turn-in, they reduce understeer- similar to what a rear sway bar does. They also let ya carry fat chicks in the back... ![]() |
Author: | aaron [ Mon Oct 27, 2008 7:57 am ] |
1310/71 wrote: aaron wrote: No matter how much you play with suspension on a mini, if you go into a corner too hard it will still do this........ ![]() ![]() ![]() ![]() That's just the hydro overcompensating for the fat basta#d in the drivers seat ![]() KB Harsh.... but fair ![]() |
Author: | Fat Boy Dave [ Sun Jun 21, 2009 6:05 pm ] |
Quote: They also let ya carry fat chicks in the back...
Cool... ![]() With the front shocks, do you need a kit or any mods or cna you just purchase the shocks from any reputable Mini spares place? |
