It is currently Thu Jul 31, 2025 5:42 am
 Post subject: Removing sliding windows
PostPosted: Sun Oct 26, 2008 7:11 pm
Ok.. How on earth!?
I believe there are three screws in the bottom sliding channel... I can only find one - are they all on the same 'side'... ie inside or outside channel?
And then once the three screws are out, does the whole lot slide to the inside and then the windows drop down with the chrome channel (with sliding seals as well?
Thanks in anticipation :!:
PostPosted: Sun Oct 26, 2008 7:13 pm
do you have the quater windows out?
PostPosted: Sun Oct 26, 2008 7:17 pm
I'm Bert , where's Ernie
sliding windows never had a quarter didnt they?
sorry for the slightly off-topic willy.
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Sun Oct 26, 2008 7:21 pm
The Mini King
willy wrote:
Ok.. How on earth!?
These screws can sometimes be hard to find because the head of screw is flat and often rusty, You can usualy feel the tip of the screw from underneath this will locate the screw for you
PostPosted: Sun Oct 26, 2008 8:04 pm
Sliding window doors never had quarter windows, no.
I have tried this John, but I can't feel any bottoms of any screws - it's like its a double panel.
Might have another go in some good sunlight ... Another thing that's not awesome about living out of home... no good shed with proper lights and tools :( Oh well
PostPosted: Sun Oct 26, 2008 8:28 pm
Another way of finding the screws is to run a screwdriver through the channels and you'll hopefully be able to feel the metal screw through the felt. They will probably need to be drilled out as the heads rust quite badly.
After the screws are out, the bottom rail and channel complete with windows should slide out towards the inside of the car. Slide the bottom out on an angle and then downwards if that makes sense.
A horrible job, take lots of care or you'll end up with lots of broken glass.
Good Luck
Steve
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
PostPosted: Sun Oct 26, 2008 8:35 pm
Thanks to all, I will let you know how I go tomorrow (if I get a chance to work on it).
Technology is a good thing in times like these :D
PostPosted: Sun Oct 26, 2008 9:04 pm
Slow-Po
Still having trouble finding a screw willy - good to see that some things never change mate. :D
PostPosted: Mon Oct 27, 2008 8:23 pm
All done. Thanks to the people that contributed with help :wink:
