Pros and Cons of owning a Mini? https://www.ausmini.com/forums/viewtopic.php?f=2&t=47107 |
Page 1 of 4 |
Author: | stevos [ Wed Oct 29, 2008 9:43 pm ] |
Post subject: | Pros and Cons of owning a Mini? |
Hi All i have been considering buying a mini for a while now, just wondering what some of the pros and cons are of owning a mini? Are they very reliable etc? these sorts of things. Cheers ![]() |
Author: | Mini Mad [ Wed Oct 29, 2008 9:49 pm ] |
Pros - They are fun - They are fun - People look at you like your crazy - They are fun - They handle well - They can be faster than bigger cars - They are a classic - They are easy to work on - They are simple - They are fun - You can't help but smile looking at them - Just sit in one and you will smile - Cons - They are expensive - They break - They are getting rare - They are a target for theives/getting picked up/rolled - Cooper S Tax - They break - They rust Random.. Seriously they are good fun, if you aren't scared of picking up a spanner or two..or three you will enjoy it. |
Author: | Harley [ Wed Oct 29, 2008 9:50 pm ] |
Pros: The way they drive! Look good Easy to customise Can be easy to work on Parts supply still relatively available Cons: unreliable, particulary on modified cars parts expensive cars can be expensive not the most secure car as far as break ins or drunk mobs go no safety features (that said, many including myself have crashed and walked) |
Author: | ryan [ Wed Oct 29, 2008 9:51 pm ] |
all pro's.... Basically its like any car. If it is in good condition and well looked after it will be very reliable. They are a good, simple car to work on. they are lots of fun. They are not very practical. They are a target for thieves and vandals. Ryan |
Author: | Ziegech [ Wed Oct 29, 2008 9:51 pm ] |
reliabilty depends on the car u have. i had a dog of an engine first off that died every 3 or 4 months and was riddled with bugs after a rebuild and now i havent had a single issue since i put my new charged engine in which u would think has more issues. they can be hard to work on depending on what goes wrong, but mainly because of the lack of space. mechanically they are simplistic enough for most people to get the basic idea of what does what and how to fix it. All you need is a drive in one to know the Pros speaks for itself. Good things do come in small packages, however you might find all other cars boring to drive after you get a mini |
Author: | Harley [ Wed Oct 29, 2008 9:55 pm ] |
ryan wrote: all pro's....
They are not very practical. They are a target for thieves and vandals. Psst.......those are cons! ![]() |
Author: | Thor56 [ Wed Oct 29, 2008 10:06 pm ] |
PRO chick magnet (if single) CON chick magnet (if in a relationship) |
Author: | ronhic [ Wed Oct 29, 2008 10:15 pm ] |
Consider a Morris 1100..... http://www.elevenhundred.com/index.php Pros -Slightly larger than a mini....60cm longer -4 doors -bigger boot -same engines as a mini -more space under the bonnet -easier to work on (see above) -less likely to have had a 'hard' life -much better ride -will do Melbourne to Canberra @100k/ph without deafening you -good handling -handling doesn't 'bite' like a minis can -similar fuel economy (if this is an issue) -less likely to get broken into/stolen/vandalised in general -not as common as a mini -won Wheels car of the year and is a classic (just nobody knows it) -cheaper to buy than a mini in comparable condition -there are some rare versions out there (Vanden Plas Princess, Riley, Wolseley, MG and Austin) -it'll make you smile (mine does everytime I drive him or walk past) -lovable rather than 'cute' Cons -Your grandmother/mother may have had one (this can be a bonus though - they may want you to have one) -could be considered a 'nanna' car as a result...but we all love our nannas -doesn't handle as sharply as a mini (see above) -people will ask you why (because everyone wants/has a mini...is a valid answer) -not as 'cute' a mini |
Author: | Thor56 [ Wed Oct 29, 2008 10:17 pm ] |
ronhic wrote: Consider a Morris 1100.....
http://www.elevenhundred.com/index.php Pros -Slightly larger than a mini....60cm longer -4 doors -bigger boot -same engines as a mini -more space under the bonnet -easier to work on (see above) -less likely to have had a 'hard' life -much better ride -will do Melbourne to Canberra @100k/ph without deafening you -good handling -handling doesn't 'bite' like a minis can -similar fuel economy (if this is an issue) -less likely to get broken into/stolen/vandalised in general -not as common as a mini -won Wheels car of the year and is a classic (just nobody knows it) -cheaper to buy than a mini in comparable condition -there are some rare versions out there (Vanden Plas Princess, Riley, Wolseley, MG and Austin) -it'll make you smile (mine does everytime I drive him or walk past) -lovable rather than 'cute' Cons -Your grandmother/mother may have had one (this can be a bonus though - they may want you to have one) -could be considered a 'nanna' car as a result...but we all love our nannas -doesn't handle as sharply as a mini (see above) -people will ask you why (because everyone wants/has a mini...is a valid answer) -not as 'cute' a mini nannas car = no chicks |
Author: | ronhic [ Wed Oct 29, 2008 10:20 pm ] |
serenity wrote: ronhic wrote: Consider a Morris 1100..... http://www.elevenhundred.com/index.php Pros -Slightly larger than a mini....60cm longer -4 doors -bigger boot -same engines as a mini -more space under the bonnet -easier to work on (see above) -less likely to have had a 'hard' life -much better ride -will do Melbourne to Canberra @100k/ph without deafening you -good handling -handling doesn't 'bite' like a minis can -similar fuel economy (if this is an issue) -less likely to get broken into/stolen/vandalised in general -not as common as a mini -won Wheels car of the year and is a classic (just nobody knows it) -cheaper to buy than a mini in comparable condition -there are some rare versions out there (Vanden Plas Princess, Riley, Wolseley, MG and Austin) -it'll make you smile (mine does everytime I drive him or walk past) -lovable rather than 'cute' Cons -Your grandmother/mother may have had one (this can be a bonus though - they may want you to have one) -could be considered a 'nanna' car as a result...but we all love our nannas -doesn't handle as sharply as a mini (see above) -people will ask you why (because everyone wants/has a mini...is a valid answer) -not as 'cute' a mini nannas car = no chicks Maybe, but they have a bench seat which is far far more comfortable than the buckets in a mini...and a backseat which is almost palatial in comparison |
Author: | Thor56 [ Wed Oct 29, 2008 10:21 pm ] |
ronhic wrote: serenity wrote: ronhic wrote: Consider a Morris 1100..... http://www.elevenhundred.com/index.php Pros -Slightly larger than a mini....60cm longer -4 doors -bigger boot -same engines as a mini -more space under the bonnet -easier to work on (see above) -less likely to have had a 'hard' life -much better ride -will do Melbourne to Canberra @100k/ph without deafening you -good handling -handling doesn't 'bite' like a minis can -similar fuel economy (if this is an issue) -less likely to get broken into/stolen/vandalised in general -not as common as a mini -won Wheels car of the year and is a classic (just nobody knows it) -cheaper to buy than a mini in comparable condition -there are some rare versions out there (Vanden Plas Princess, Riley, Wolseley, MG and Austin) -it'll make you smile (mine does everytime I drive him or walk past) -lovable rather than 'cute' Cons -Your grandmother/mother may have had one (this can be a bonus though - they may want you to have one) -could be considered a 'nanna' car as a result...but we all love our nannas -doesn't handle as sharply as a mini (see above) -people will ask you why (because everyone wants/has a mini...is a valid answer) -not as 'cute' a mini nannas car = no chicks Maybe, but they have a bench seat which is far far more comfortable than the buckets in a mini...and a backseat which is almost palatial in comparison ooo check and mate haha |
Author: | minidrifter [ Wed Oct 29, 2008 10:30 pm ] |
hahaha i thought you had it there daneo ![]() ![]() ![]() |
Author: | superSeven [ Wed Oct 29, 2008 10:31 pm ] |
pro's Customisable - stripes, wheels, seats, mirrors, dashboards, roof decals etc etc Timeless design Better than the new ones Chicks adore them - great for when the wife leaves you for spending too much time on the mini. Random conversation starter at petrol stations Feels good giving them constant attention and tlc. Great for parking Sneaking down half lanes between traffic and parked cars. Wont depreciate You get a new best friend in your local tow driver/trailer hire/mobile mechanic cons Too many customisation options.. gets expensive! Random conversation starter at petrol stations = not good when late to work! Wive's often dislike them due to constant attention and tlc and expenditure Can break down when doing silly things like full throttle from standstill doing a u-turn.. one mini get's lonely in the garage.. often two are required.. have a habit of sitting around for years.. decades.. not moving very far.. |
Author: | mini_mad_matt [ Wed Oct 29, 2008 10:42 pm ] |
Parts seem to be thought of as expensive, but no more so then the next car due to the availability of most mechanical parts But like everyone else is saying it's more then just a car, its a love affair |
Author: | superSeven [ Wed Oct 29, 2008 10:46 pm ] |
ronhic wrote: Maybe, but they have a bench seat which is far far more comfortable than the buckets in a mini...and a backseat which is almost palatial in comparison but isn't the back seat wasted on stuff like picnic baskets.. straw hats.. tissue boxes.. touring maps.. |
Page 1 of 4 | All times are UTC + 10 hours |
