duplex timing chain
https://www.ausmini.com/forums/viewtopic.php?f=2&t=47182
Author:  badassmini [ Sat Nov 01, 2008 5:22 pm ]
Post subject:  duplex timing chain
will a 1100 duplex timing chain and gears fit a 1275. i know stupid question but i really don't know.
Author:  drmini in aust [ Sat Nov 01, 2008 5:36 pm ]
An A series duplex chain and sprockets will fit any A series motor, from 850 block to 1275 block.
Author:  badassmini [ Sun Nov 02, 2008 8:42 am ]
thanks Doc
Author:  Rodney [ Mon Nov 03, 2008 9:46 am ]
Hey Doc....I'm probably wrong (bows to your far superior knowledge) but don't you have to replace some of the bolts that hold on that plate behind the timing chain, with countersunk screws - also got to countersink some of the holes??? But like I said, I'm more than likely 100% wrong.
Author:  drmini in aust [ Mon Nov 03, 2008 11:22 am ]
Yeah you do need to countersink the 2 lower holes on the backplate, then use csk screws- either socket head or Phillips ones.
Also some timing covers foul on the chain inside, check and do cover surgery as needed.
Author:  Rodney [ Mon Nov 03, 2008 5:57 pm ]
yay....the old grey matter isn't turning to mush after all. Cheers Kev
