It is currently Sat Jul 19, 2025 4:25 pm
 Post subject: duplex timing chain
PostPosted: Sat Nov 01, 2008 5:22 pm
will a 1100 duplex timing chain and gears fit a 1275. i know stupid question but i really don't know.
Cheers Dan
PostPosted: Sat Nov 01, 2008 5:36 pm
Online
An A series duplex chain and sprockets will fit any A series motor, from 850 block to 1275 block.
PostPosted: Sun Nov 02, 2008 8:42 am
thanks Doc
Cheers Dan
PostPosted: Mon Nov 03, 2008 9:46 am
Hey Doc....I'm probably wrong (bows to your far superior knowledge) but don't you have to replace some of the bolts that hold on that plate behind the timing chain, with countersunk screws - also got to countersink some of the holes??? But like I said, I'm more than likely 100% wrong.
Rod Image
PostPosted: Mon Nov 03, 2008 11:22 am
Online
Yeah you do need to countersink the 2 lower holes on the backplate, then use csk screws- either socket head or Phillips ones.
Also some timing covers foul on the chain inside, check and do cover surgery as needed.
PostPosted: Mon Nov 03, 2008 5:57 pm
yay....the old grey matter isn't turning to mush after all. Cheers Kev
Rod Image
Users browsing this forum: drmini in aust, watsupskip and 71 guests
