It is currently Fri Jul 18, 2025 1:45 pm
PostPosted: Mon Nov 03, 2008 7:21 pm
G'day all,
I have been working on my mini and have started stripping the doors ,how in the hell do you remove the two screws that secure the door handles :?:
Do you have to drill 2 holes in order to allow access to the screw's or is there some secret :?
Any help would be appreciated
cheers Anth
PostPosted: Mon Nov 03, 2008 7:54 pm
There are 3 screws not 2.
Stick a screwdriver through the hole where the chromed cap was.
Of course, you have to remove the window, & door lock etc first.
Fun job, I've just done mine... :lol:
PostPosted: Mon Nov 03, 2008 8:17 pm
Bugger another screw! :wink:
everything is stripped out of them,it just these handles stopping me from putting them back to bare metal.... :twisted:
i have removed the chrome cap ,i just did think there was enough room to get at it with a screw driver will try tmrw
any secrets :wink:
cheers Anth
PostPosted: Mon Nov 03, 2008 8:19 pm
The circlip has to come off first, it is a bastard to get back on, so I leave mine off- just bend that U-shaped link lever out a little and clip is not needed.
PostPosted: Tue Nov 04, 2008 9:08 am
I have just reassembled my doors after painting them. Allow yourself lots of time, and don't become too attached to the skin on your knuckles!
I found the door handle screws not too bad to get at.... Just make sure you use the correct size phillips head so that you don't strip the screws.
