It is currently Wed Aug 20, 2025 10:17 am
PostPosted: Sat Nov 08, 2008 9:24 pm
has anyone delt with this product as they say that they are better than por15???
http://www.rustbullet.com/?source=adwor ... agodTSKAOA
PostPosted: Sat Nov 08, 2008 10:08 pm
I tried to buy some Rust Bullet here in Sydney last year.
The importer is in NZ, they have someone here who resells it. After the latter ignored several of my emails I gave up, bought POR15 instead.
There is also an Australian made one now, called Xtroll or something, they reckon it's as good or better.
PostPosted: Sat Nov 08, 2008 10:18 pm
Milatsmadmini
Thats the one Kev,
it really is the bees knees, im using it at the moment with my mini build and its tops! and it acts with the rust, sorta turning it into not quiet rust, very close to metal... Rust Conqurer is the stuff to get... there are a few Zinc based paints (similar to POR15 marine i think? the silver stuff...) and its a good anti-prevantative.
There used to be a distibuter in Sydney (in Pendle Hill) but they closed down a few months ago (thats when i got mine... they were basically throwing it out!) After some poking around a bloke on the Moke forum found a guy around newcastle that also distributes it, if ya want his number ill pass it on to you.
back to topic... lol never heard of Rust Bullet... damn yanks... lol
oh and XTroll is all Australian made and owned :wink:
PostPosted: Sat Nov 08, 2008 10:21 pm
I have never been impressed with POR15. It is a lot of marketing hype for a very simple product. It is bloody expensive for what it is.
If you want to see pure BS did back through some old car mags from when POR15 hit the market, it was advertised as Paint Over Rust 15. You didn't need to clean up or wire brush the parts, you just painted straight over the rust.
The company got a real bad reputation for a while as they would blame the customer when the paint fell off! So they added the Marine Clean and the Metal Ready steps to the procedure. But they will still blame the customer if there is a problem. :lol:
PostPosted: Sat Nov 08, 2008 10:24 pm
Milatsmadmini
how true that one is....
XTroll is the way mate!
PostPosted: Sun Nov 09, 2008 6:17 am
http://www.corrosion-tech.com.au/Xtroll ... ntages.pdf
Doesn't give much info there about overcoating with acrylic or 2 pack products that I can see... :?
PostPosted: Sun Nov 09, 2008 7:12 am
They still tout the paint as going straight over rust. They state that the paint is best put on over rough or corroded metal, but then carry on about the other metal preps that must be applied...
I love the glossy black finish, but I hope it remains stuck to the metal :shock:
PostPosted: Sun Nov 09, 2008 8:05 am
KBS.
ITS THE SAME AND ITS CHEAPER
http://www.kbs-coatings.com.au/
Member VMCI #19
PostPosted: Sun Nov 09, 2008 8:17 am
Rookiepilot wrote:
KBS.
Looks to be the same price, I paid around 70 for the POR15 topcoat as well.
PostPosted: Sun Nov 09, 2008 9:10 am
http://www.corrosion-tech.com.au/Xtroll/Rust_Conqueror_Advantages.pdf
If you have a look at this one: http://www.corrosion-tech.com.au/Xtroll ... ealers.pdf, Says to be "careful" with strong solvent paints such as 2 packs etc.
It suggests using the G1 primer as a barrier coat over it before painting with 2 packs, But then in this: http://www.corrosion-tech.com.au/Xtroll ... rimers.pdf, it says it blisters under solvent paints?!?
Very confusing website!
Andrew
 Post subject: Jay
PostPosted: Sun Nov 09, 2008 11:10 am
My moke has been done in xtrol and its $33, for a 1ltr tin, which was plenty....
*Reasonable pricing
*I come to you..
Jay: 0431404607
Users browsing this forum: No registered users and 379 guests
