Rubber Urothane Sportspack Arches https://www.ausmini.com/forums/viewtopic.php?f=2&t=47446 |
Author: | _666_ [ Mon Nov 10, 2008 9:11 pm ] |
Post subject: | Rubber Urothane Sportspack Arches |
ok its probably a bit late now.. but whats the best way to fit the Ruber Urothane relica Sportpack Arches ? i got the minispares template but thats not accurate.. is it best to work your way from one end ? my car didnt turn out the best... Nick |
Author: | mad-mk1 [ Tue Nov 11, 2008 12:30 am ] |
do they have the bolts ? are they the replicas from minisport? because if they are theyre horriblee to fit, (which i was warned when i purchassed them) pics maby or ill talk to ya in the morning.... where you having trouble? |
Author: | EAB [ Tue Nov 11, 2008 8:33 am ] |
if its teh black plastic bolt on ones i had to rezize the template when i printed it to 108% or something, then it worked ok, still a lot of fiddling around, i'll try and get some pics up for you, turned out ok tho. i'd start at one end and work your way around. use the hole on the back ones, lines up with the screw that holds the cover over the grease nipple. for the front you need to line up the seam and the bottome edge to start off with. i made a template out of cardboard to help me out when i was doing it |
Author: | _666_ [ Tue Nov 11, 2008 10:58 am ] |
EAB wrote: if its teh black plastic bolt on ones i had to rezize the template when i printed it to 108% or something, then it worked ok, still a lot of fiddling around, i'll try and get some pics up for you, turned out ok tho. i'd start at one end and work your way around.
use the hole on the back ones, lines up with the screw that holds the cover over the grease nipple. for the front you need to line up the seam and the bottome edge to start off with. i made a template out of cardboard to help me out when i was doing it crap that hole was for the grease nipple ? haha i thought it was a tex screw hole.. so i drilled a hole into the sill and put a bit screw in threr... |
Author: | floss [ Tue Nov 11, 2008 9:11 pm ] |
yeah they are a bit of a bitch to put on. Took me ages to get them looking right. they tend to fold and crease and generally take ages to look good. You should try getting them on a clubby van. |
Author: | floss [ Tue Nov 11, 2008 9:20 pm ] |
ohh I don't know if this is right but I read on tmf that it is really hard to get greasy nipples with sports pack and that people replace the rear nipple with a 90 degree one to make this easier. This leads me to think maybe the hole isn't for the nipple. I did mine months ago and haven't seen the shell since then as at the beaters so can't remember. Could be wrong, usually am ![]() I just said greasy nipples and beater... tee hee David |
Author: | _666_ [ Wed Nov 12, 2008 1:19 am ] |
yeah i had a look today. i doubt its for the grease nipple.. i think it would look out of place that far back |
